Two more stoves for my ever growing collection
Discussion in 'Stove Forum' started by Johnathan, Sep 17, 2019.
  1. Johnathan Canada
    Stony Plain, Alberta
    Well, I have added two more stoves to my growing collection. I have now got 4x 3 burner stoves, 12x 2 burner stoves, 1x 1 burner stove, 4x propane stove, 11x lanterns (2 are propane), 1x catalyst heater
    Picked these two up last night. The one is an undated 4M stove and the big one is 5/67 446 model. They both work. The only problem I had was with the large stove not having a blue flame on high, it was good on a low to medium flame, but once I went above it went more yellow/orange flame. Could be the fuel is old?
    Anyways, here are the pics! I have to pull apart the 4M and clean it as it is pretty greasy and as you can see, the previous previous owner had actually repainted the unit. And the first couple flame shots that are really high are when I first started it.
    20190916_192334.jpg 20190916_192338.jpg 20190916_192341.jpg 20190916_192345.jpg 20190916_192349.jpg 20190916_192357.jpg 20190916_192431.jpg 20190916_192434.jpg 20190916_192445.jpg 20190916_192452.jpg 20190916_192513.jpg 20190916_192520.jpg 20190916_192526.jpg 20190916_192733.jpg 20190916_192744.jpg 20190916_192748.jpg 20190916_192752.jpg 20190916_192759.jpg 20190916_192810.jpg 20190916_192812.jpg 20190916_192824.jpg 20190916_192827.jpg 20190916_192846.jpg 20190916_192901.jpg 20190916_192905.jpg 20190916_193023.jpg 20190916_193027.jpg 20190916_193030.jpg 20190916_193051.jpg 20190916_193245.jpg 20190916_193249.jpg 20190916_193309.jpg 20190916_193407.jpg 20190916_193416.jpg
  2. Lennart F Sweden
    Vänersborg, Sweden
    I stopped counting - too tricky to figure out what I have, now I just try to buy less.
  3. Simes
    Simes Subscriber
    Now that's a motto to try to live by.
  4. HaakonJ
    HaakonJ Subscriber
    Norway
    To stop counting? I agree :lol:
  5. snwcmpr
    snwcmpr Subscriber
    Quite a few years ago I stopped counting at 100.
  6. Majicwrench
    Majicwrench Subscriber
    The orange/yellow flame on 3 burner.... there has to be enough fuel available to run three burners, so when just running one on high there is too much fuel. Once you open all three, it should straighten out. Also, any stove that hasn't run in a while will have "things" it needs to burn off, which produces some colors.
    I don't have 100, but I would still hate to count...
  7. Simes
    Simes Subscriber
    I stopped counting when I ran out of fingers and toes, I seem to remember I once worked out I had over 40.....:D
  8. Twoberth
    England
    Don’t know how many stoves I have, probably about 50.
    Fuel types ratio is probably 10:10:1:1 for LPG : paraffin : meths : petrol.
    Also, for ever 3 stoves I buy, I probably only keep 1.
  9. afoton
    I stopped counting when I didn't know what _1_ stove was anymore. Some stoves became parts, some stoves was not complete, so parts was swapping around. Counting wasn't an easy task anymore.
  10. igh371
    but you can count up to 100 with fingers alone:-s
    adding in toes too maybe you could reach 1000 :D
    by then it might be time to think about slowing down? or moving to a larger shed? :lol:
  11. snwcmpr
    snwcmpr Subscriber
    @Majicwrench is correct. Unless I am using all 3 burners I do not open it all the way. Same with a 2 burner.
    I turn it down, when yellow, unti I get blue.
    On an old stove, I gently tap the generator, when hot, to dislodge particles. You can see sparks fly out of the burner showing their presence. Then I turn the stove off BRIEFLY to put the pricker through the jet, then back open, before the flame goes out. Repeat many times.
    Ken in NC
  12. Simes
    Simes Subscriber
    @igh371, being a bit decimal there, using fingers you can get over a thousand in binary.....
  13. igh371
  14. janders
    janders Subscriber
    1048576 if you manage to use your toes as well... (Old binary computer geek here :oops:)
  15. Twoberth
    England
    Even @Doc Mark doesn't have that many stoves.
  16. Rangie
    Rangie Subscriber
    Hmmmm........ :-k
    Alec
  17. Doc Mark
    Doc Mark Subscriber
  18. snwcmpr
    snwcmpr Subscriber
    The hobbit hole is endless, or so I hear.
  19. boknasild
    boknasild Subscriber
    I tried to look for some deep radar scans at Doc Mark position but it was obscured/cloaked like Area 51.
    I wonder how big the halls in his cellar are. :lol:
    Have a nice weekend Mark
    Bjørn
  20. IvanN
    N.E. Oregon
    Not a nasty, dirty, wet hole, filled with the ends of worms and an oozy smell, nor yet a dry, bare, sandy hole with nothing in it to sit down on or to eat: it was a hobbit-hole, and that means comfort.
