Two tins
Discussion in 'Stove Forum' started by ton visser, Jan 15, 2021.
  1. ton visser
    ton visser Subscriber
    Wormer, Holland
    Hello, I bought two tins this week, the first one a Primus and the second one an Optimus.
    The first one, the Primus is a bit bigger than the second one, giving space to a Primus No 210.
    But the second one, the Optimus, is it meant to store a stove in? And if so which number? And if not what was the purpose of this tin?
    Ton.
  2. kerophile
    Hi @ton visser . What is the depth of your Optimus Tin?
    Please provide measurement or photo.
  3. ton visser
    Wormer, Holland
    Another picture to make clear what I mean, the Optimus tin together with an Optimus 96.
    The stove does not fit in the tin, I did not try to press to make it fit.
    The size of the stove is 11.5 cm and the tin is 11 cm inside.
    Ton.
  4. Wim
    Wim Subscriber
    Maybe an earlier model 96 with the fixed legs?
  5. hikerduane
    Some of my Primus 96's are a tight fit.
  6. Spiritburner
    This tin is 11cm X 14cm X 7cm.
  7. ton visser
    Wormer, Holland
    Same box spritburner, and the stove, a 96 too?
    And it fits without pressing it into the tin?
    I gave it another try and as Duane says it is a very tight fit.
    So no reason for any more panic.
    Ton.
  8. Spiritburner
    Aye, a 96. I notice your's has the 'modern' burner plate.
    This may help with the packing:
