Unnamed Range Stove (possibly Optimus/Lux/Gloria)
Discussion in 'Other brands' started by Tony Press, Jul 22, 2021.
  1. Tony Press
    This stove has been discussed here.
    The same filler cap as an Optimus, but without the globe inside the circle. No markings on the pressure release screw.
    The burner is an early Primus burner, not original to the stove.
    Testing and running
    As it came
    Note on the left hand side, the pipe that would have fed the spirit cup pre-heater from a small funnel attached to the cast frame/stand.
    Note the internal construction of the riser.
    A few fettling notes:
    The pump tube needed to be carefully deburred from what cause, I am not sure.
    The rusted parts were treated in citric acid and painted. The steel plate that acts as a heat shield was painted close to one of the colours (red) that was on the stove. The other colour was black. I could not determine which came first.
    Primer paint.
    This is where the spirit funnel would have been attached to the feeder pipe. I have not replaced the funnel or the pipe as the stove does not require them, but if I find the dimensions of the original funnel I may manufacture a replacement.
    I did not paint the cast iron stove stand as I could not determine which was the original colour, if indeed there was an original colour. Instead I cleaned the stove of paint and rust, and treated it with stove-black, then baked it at very high temperature in the BBQ, then polished it. The reflection of the stove-black in the full sunlight appears grey, but the actual colour is much darker, as seen in the photos above.
    Seals and washers from the Fettlebox.
    This is a rather wonderful stove. It runs well; looks good; and the cast iron is not damaged.
    More light to shine on the mystery of this stove...
    @optipri @igh371 @Nicola Francesco Elia @abbahco1 @OMC @Rodger Willows
  2. BigScott
    BigScott Subscriber
    Shetland Isles
    A fine job of the stove! I think you should call it 'The Swedish Gymnast' as it reminded me of when my kids did things like this!
