Unused Coleman Apex (Peak 1) dated October 1994
Discussion in 'Other Models' started by presscall, Jun 16, 2019.
    presscall United Kingdom Subscriber SotM Winner
    Boxed and unused, complete with accessories of kerosene burner, set of spares, tripod feet and stuff sack by maker ‘Manfield’.
    Box front and back
    Contents as boxed.
    Instruction sheet.
    ‘Things you should know’ extract from the instruction sheet, including a reference to the ‘chugging’ characteristic of these stoves.
    The stuff sack.
    The stove and date stamp.
    My experience of use of one of these stoves was of THIS example.
    That stove presented fuelling problems because of wear of the atomising hole in the plastic elbow joint of the pickup tube, which I constructed a brass replacement for in a fettling post HERE.
    In this unused example, the primary concern if it were to become a ‘user’ (it won’t in my hands) would be the crack at the flexi-hose connector on the fuel pump.
    Mike (@HunterStovie) had contributed very useful discussion in THIS thread, and it’s a well-known and regrettable phenomenon.
  2. HunterStovie
    Parker, Colorado, USA
    @presscall
    That's a really cool variant. I've never come across the "E" before and it's box is definitely unique.
    Too bad about the pump.
    Mike
  3. Harder D. Soerensen
    Denmark
    Very nice indeed.
    I have a couple af 550’s so I am wondering if its worth getting the Apex as well?
    I have successfully sealed pump cracks like that with this 2-Component “Chemical Metal”
    Chemical Metal
  4. presscall
    Hi Harder, good to hear from you. I would recommend one - pump issue aside - because they’re a very effective stove, controllable and with a wide flame pattern well dispersed like your 550 to work well as a cookstove and not just a water boiler. Kerosene generator offers another fuel option, but it robs it of the quick-start function possible with gasoline (needs an alcohol prime with kero).
    Thanks for the adhesive/filler tip. I’ve already got the JB Weld product Mike @HunterStovie recommended - and it’s black. Not a lot of point using it on the unused pump though, which remains as a conversation piece to illustrate a characteristic of the stove and what killed off pumps for many.
  5. Harder D. Soerensen
    Denmark
    And the same my friend @presscall
    The chem metal hardens up in almost the exact same grey as some of the MSR-pumps and Sigg’s.
    Arrgh - cursed be you John - now I feel that well known deep down desire lurking for an Apex 1. Would keep it on CF though - for the same reasons you mention.
    (I still have deep respect for your fantastic run-throughs and tutorials!)
  6. skorpiius
    skorpiius Subscriber
    I highly recommend one. Also an Apex II naturally. Really it's not a proper collection without the black, silver and the copper coloured Exponent version. Of course the 550b shares the excellent windproof burner design, and there you need the silver Peak 1 as well as the copper Exponent variant.
    Also these are getting old so I highly recommend getting doubles of each for spare parts.
  7. Harder D. Soerensen
    Denmark
