Villiers Mar-vil restoration.
Discussion in 'Villiers' started by Robert Radcliffe, Apr 1, 2019.
  1. Robert Radcliffe
    Robert Radcliffe United Kingdom Subscriber
    Stockport UK
    I've removed rust and sprayed the interior with a heat resistant Matt black enamel.
    20190401_195505.jpg 20190401_195600.jpg 20190401_195615.jpg 20190401_195652.jpg
    I finished the outside with a black crackle finish which to be honest I'm not happy with.
    The crackle effect is uneven.
    The stove has been a battle and despite decoking the vapouriser it stopped working. The air and fuel intakes seemed clear so I water quenched the vapouriser repeatedly after heating to try and clear more carbon. It seems to have worked for now at least.
  2. presscall
    @Robert Radcliffe
    Great stuff Robert. Using the Aspen 4 should keep your vapouriser in good shape indefinitely
    You might want to borrow a tip from Coleman shut-down procedure and open the air intake (lever on the Coleman, knob to unscrew on the Villiers) to lean the mixture and depressurise the tank at the same time - has the effect of blasting away any fuel-rich deposits (apparently).
  3. Robert Radcliffe
    Stockport UK
    That sounds like a great idea John. I'm prepared for this one to be a bit temperamental so any thing to help prevent that vapouriser getting carbon deposits is welcome. Regards Rob.
