Washing Soda - where to buy?
Discussion in 'Fettling Forum' started by John Leah, Nov 30, 2009.
  1. John Leah
    Devon, UK
    I want to use electrolysis to rid some on my stoves of that pesky rust so need some washing soda. Easy enough you may think (I certainly did) but all the shops I've tried have looked at me blankly and asked: "do you mean washing powder?"
    It really shouldn't be this difficult so any suggestions where in the UK I should try next?
    Perhaps if I had a brand name to try out in the next shop I may have more success - but then again...
  2. SNOWGOOSE
    In ASDA or TESCO
  3. John Leah
    Devon, UK
    Perfect - just what I was looking for, thanks.
    I'll print the picture, take it to the store and when the next spotty yoof asks if I want washing powder I'll be able to show them the picture and say: "NO I "$%^£!* well don't!". :lol: :lol:
  4. Stelllar
    Hi there, I use baking soda, environmentally friendly, cheap and readily available, 4 tablespoons make 1 Liter of water conductive, for small items a stainless steel spoon or fork connected to the positive ( + ) terminal hanging in the solution next to the item being de-rusted connected to the negative terminal ( - ) works just fine, Epsom salts works also. Cheers'
  5. lanevitt
    lanevitt Subscriber
    Hi Stellar..
    S/steel is a bad idea in an electrolysis bath.
    Iron....steel is the way to go. Chromium in the s/steel when released is harmfull to the user and bad for the environment.
  6. John Leah
    Devon, UK
    Hi Stellar,
    Yes, I'd read somewhere that baking soda works but it tends to be much more expensive than I'd imagined a washing product to be. However, if, despite the pointer that Snowgoose gave me, I still can't get any I'll use baking soda - I'm sure my wife wouldn’t notice it's all gone :lol:
    Re using a stainless for the anode: I'd also read Here this causes the chromium component to leach out making the water toxic. Of course this may all be fiction but then again...
  7. fyldefox
    fyldefox R.I.P.
    John look in the cleaning secton, not the washing powder section !
  8. itchy
    No, its cheaper. Baking soda is about the cheapest thing you can buy at a supermarket in the states, something like 50 cents a box.
    And you only use a small portion of it. Too much and you will drawn too much current, you don't want to heat the water. ;)
    In any case, washing powder may work as well, and a little detergent in with the soda will help cut through oil and dirt.
    Tip: use the old stuff from the kitchen, buy your wife a new box for the holidays -- Big Spender.
  9. Stelllar
    Hi there, thanks for the info, I was not aware of this.
  10. Stelllar
    Hi there, thanks for the info, I purchase baking soda from the Bulk section of the local Super Store here in Canada, sorry I do not have the price but it was something like 12 cents per hundred grams ? and as I recall a couple of dollars for a large plastic bag full. Cheers'
  11. lanevitt
    lanevitt Subscriber
    Hi again
    If you enter electrolysis in the search box on the right of the page, there is a bundle of information and ideas on the subject from many of the CCS members. Its good reading. (as is 99.999% of the information here)
  12. Stelllar
    Thanks, I'll check it out. All the best.....
  13. SNOWGOOSE
  14. John Leah
    Devon, UK
    Hi Snowgoose,
    Thanks for the link, their soda crystals are so cheap I'll certainly be buying from them.
    I have found a small bottle in ASDA but it was much more expensive although it has given me something to play with. It appears where I was going wrong was to ask for 'washing soda' in the washing powder departments while it's more likely to be found as 'soda crystals' in the cleaning department.
    For my electrolysis experiments I've dusted off an old power supply I used to use for charging my caving lamps which has much more control over the voltage provided.
    In fact, I think I'll go and wire it up right now :)
  15. rik_uk3
    South Wales UK
    Wilkinsons sell it and either Tesco or Asda, can't remember which.
  16. RonPH
    ok, while we are on the topic of electrolysis, I have 3 rusted metal potlegs, do I have to do it one at a time or can I just connect all 3 of them on to the negative side of the terminal?
    Ron
  17. bajabum
    bajabum R.I.P.
    You can hook up lots of metal, just keep + and - seperated a bit...
    Hot water speeds things up too!
  18. RonPH
    Thanks, will be my first and show post some pictures.
    Ron
