wire mesh for lip stick 96
Discussion in 'Stove Forum' started by CRAZY CRAB, Sep 1, 2020.
  1. CRAZY CRAB
    CRAZY CRAB Ireland Subscriber
    could wire wool be used instead of wire mesh in the lip stick of a 96 stove, has any one tryed it, or can i be the first and live to tell the tell
  2. Jeopardy
    Jeopardy Subscriber
    In my humble experience, the mesh inside the burner lipsticks is brass to get good thermal conductivity into the fuel and avoid any risk of rust.
    Regards
  3. Doc Mark
    I agree with @Jeopardy , and think that brass is the best way to go. I did question whether steel mesh would work as well, some time back, but in truth, in the one stove I got that was setup that way, the steel mesh had rusted and corroded. After that, I've stuck with brass mesh. Works for me.
  4. hikerduane
    Plumas County, CA
    Also, I think wool would tend to send out tiny bits now and then. I use 40 ct brass mesh.
  5. Ian
    Ian Subscriber
    West Yorkshire
    If you used Brillo pad, your stove could blow bubbles.
    I'll get my coat ...
  6. Doc Mark
    Hilarious, Ian!! :lol: :lol: :thumbup:
  7. G1gop
    Cheshire UK
    I recently used steel wool when I had no brass mesh. It worked well but yes there was the occasional orange fleck in the flame.
    When the brass mesh arrived I changed it and the steel wool was burnt around the top but was still intact.
    so My experience is yes you can use it but it's not 100%
    Alan
  8. Harder D. Soerensen
    Denmark
  9. CRAZY CRAB
    been doing some experimentation with different stuff, wire wool and aluminon, wire wool a bit on the dangerous side, ally is ok, and is very cheap
  10. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    Be aware that aluminum will corrode in contact with many other metals, if any moisture is present.
    ....Arch
  11. Sternenlicht
    Sternenlicht Subscriber
    Hürtgenwald
    Why don't you want to use brass mesh? It works since decades and is cheaply available. I would spend my time for the other fine projects you have!
    Ciao, Bastian
  12. CRAZY CRAB
    its called, being inventive and experimental, why pay £8 when you can pay £2, thats a saving of £6, for 5 extra beers, going to get a stainless steel scabbing pad, to see it that works,
  13. Twoberth
    England
    You could have no mesh and 6 beers.
    Depends on the stove, but I have inadvertently run lipstick stoves periodically for many months without gauze and have had no problem with maintaining vaporisation. The gauze does act as a filter, but a clean tank and pre-filtered fuel help.
  14. afoton
    My Primus 96 will not maintain vaporisation for many seconds without brass mesh.
  15. Twoberth
    England
    As I said, it depends on the stove.
    It also depends on whether there is a pan/kettle on the stove, which help.
  16. CRAZY CRAB
    cant drink 6 beers, getting old, :)
  17. IvanN
    N.E. Oregon
    I used a copper pot scrubber, like a Brillo Pad, in one, it seems to work fine. Ivan
