xgk priming pad replacement
Discussion in 'Fettling Forum' started by edman, Aug 17, 2011.
  1. edman
    Hi to All,
    Wonderful site, this site is really fun! I have a question regarding an xgk ex stove.The priming pad in the stove has fallen apart, I would like to change it, but I have no idea how to. I would appreciate it if someone could give me some tips on the how to repair.
    Again Thank You for having such as site.
    edman
  2. Knight84
    Hello and welcome to the site!
    You are talking about the newest model of XGK stoves right. The XGK EX has a pin that runs through the stove. A spring clip/nut or push nut holds the pin on both sides. You need to remove these clips/nuts then the pin will slide out. I don't have the stove in front of me but I know someone will be along to help. Sorry I couldn't be of more help.
    If I recall you might be able to just slide the new pad under the burner bell. Through one of the slots between the feet. :-k
    Jeff
  3. edman
    Wow, you are so prompt , and Thank You. I Will try this as soon as I can get a pad for it. Thank You for letting me part of this site, and for all your help.
