Yellow Optimus 22 twin burner
Discussion in 'Stove Forum' started by Johan Le Roux, Dec 4, 2019.
  1. Tony Press
    Great job, Johan. :thumbup:
  2. IvanN
    N.E. Oregon
    looks great!
  3. Robert Bruce
    Springrange NSW Australia
    That looks great, well done. Like the blue it’s good.
    Rob
  4. Andrew
    Port Elizabeth South Africa
    Looks good. I sprayed a Primus 111B with the same paint but it did not turn out that good.
  5. Cookie
    Florida
    That blue is rocking !
    @Andrew Let me pass on a tip for anyone wanting to use a spray can if I may. I learned by accident years ago that replacing the spray nozzle cap with one from a can of carburetor cleaner shoots a long even spreading cone out. Stand 6-8' feet away and get a nice even light coat. Once you have found a nozzle that you like mark it and keep it separate for DIY jobs. It helps to keep the streaks and runs down to a minimum. It is also a great way to give a mist coating for a hue effect.
  6. Simes
    Simes Subscriber
    A shaving foam nozzle may not be advisable I guess. Although it depends on what sort of finish you tequire, not an experiment I'll be trying in a hurry.
    Although I may adopt a previous recommendation to keep the cans warmed in water.
  7. Harder D. Soerensen
    Denmark
    Another little trick is to make sure your object is reasonable warm - helps minimize the runners
  8. monkeyboy
    Norte Mudzoory
    wow. great paint job. looks original from here.
    the 22 has been on my radar for a long time. i’ve seen a few on fleabay but i don't have an account.
    maybe one of these days i’ll run across one.
    i can hope.
