Lytham Tiddler Stove Setup/Parts
March 28 2004 at 1:46 AM
bsunder
In my troops storage room, I happened to stumble upon this Lytham Tiddler stove. It is made by Lytham Leisure Products in Lancaster, UK. It is a fairly old stove, my guess is about 20 or so years.
I am not quite sure how to work this little guy, but I am quite interested in how it does.
If anyone can tell me ANYTHING about this stove, it would be greatly appreciated. Also, if you could also post a set of visual diagrams with directions if possible, so that it will be much less painstaking in the setup process.
I would also like to know what kind of fuel and fuel bottle that this guy can work off of. THANK YOU.
 Respond to this message
AuthorReply
Spiritburner
Re: Lytham Tiddler Stove Setup/Parts
March 28 2004, 12:05 PM
These were certainly available as far back as the late 70's. These would fit the resealable cartridges (assuming the threads are still the same today) - once connected you opened the valve & lit the burner. There was also an adapter available to enable it to be used with the piercable cartridges. I don't think this model had a preheater that warmed the gas before feeding it to the burner so it is important to keep the gas cartridge upright to prevent flaring. It was very much a contempory of the Alps/Vango 7000.
The stove should be very simple to set up & use but given it's age I would be wary of valve seals & perishing of the tubing.
Lytham also made 2 lighter models the Titch & the Lightweight Titch.
This message has been edited by spiritburner on Mar 28, 2004 12:37 PM
bsunder
Info
March 30 2004, 10:59 PM
Thanks a lot, Spiritburner.
The next night, I went to my garage and lit the stove up. It worked great! It was very easily adjustable and put out a good flame and simmered quite well.
I used an isobutane cartridge that was resealable. I found the adapter and hooked it up. It had no trouble piercing the cartridge.
I found no leaks in the hose to be found or seen, so thats good.
I had no trouble lighting the stove at all. Only one spark with a lighter and the stove was ablaze.
Thanks again for all of your info and precautions for this stove. I plan to use it often.
