520 military stove stress cracks
April 22 2004 at 9:18 PM
gene
Is it common to have stress cracks with the brass tanks on these stoves and if so without me having to fill up with fuel to find out, does it make these stoves useless?
 Respond to this message
AuthorReply
Chuck
Testing for leaks and cracks
April 23 2004, 1:09 PM
Hello,
I have read on this forum that the older 'GI stoves' (pre-1945) tend to have stress cracks. What you can do is to get a bucket of water. Add pressure to the stove by pumping up the tank (fuel is not needed) and submurge the tank. Bubbles will tell you the story.
You have two choices if you find cracks. One is to wait for an incomplete one to sell on e-bay or maybe someone on the forum has an old tank. I wouldn't recommend soldering the cracks. A leaking fuel tank is an accident waiting to happen.
Chuck
Handi Albert
Leaking tanks
April 23 2004, 1:30 PM
I have solderd up about 30 tanks or more. only 1 came back to me where I missed a small crack. None of these has returned with a leak where I had solderd previosly. They may give out as time goes on I don't know.
Just because I have done this it does not mean every one can.
There is another way of sealing these tanks from the insides. There is a solution that they used in the WW2 on the tanks of the planes when they got bullet holes in them.
What this stuff is and where to get it from I don't know. Here in Aust I am told we can get it from the Ford motor Co.
Albert
Chuck
melting solder
April 23 2004, 3:50 PM
Albert,
How did you stop the solder from melting on previous places on the tank? I have heated up one section only to have solder come loose on the other side where I previously applied the solder. Do you use some type of a heat sink?
Chuck
Bryan Miller
Patching tanks
April 23 2004, 4:33 PM
I have been sucessful in patching tanks with a brass plate soldered on. You can form a patch with thin gauge brass provided that it is a simple curve (curved in one direction only) It is difficult to shape the patch if it was a compound curve (curved in two directions). Basically you form the patch to be a snug fit with the split in the middle of the patch. Clean and tin the contact surfaces of the patch and tank. Clean and flux the tinned surfaces. Put the patch in place then heat it until the solder melts and fuses. Leave it to harden and then clean the solder off the surrounding brass. It is neat and seems to work all right. The brass patch is more capable than solder to take the pressure formed when the tank is in use. Basically it is the same as patching a punctured inner tube.
Handi Albert
Re-melting solder
April 24 2004, 2:28 PM
As Brian has sergested you can put a patch over the crack Yes this is stronger. It is not as neat.
Chuck If the solder is melting in other places you are getting the brass too hot where you are trying to solder.
The main reason for this is Your job is not clean. Also you are trying to force the solder on. If you are trying to force the solder on Your job is not clean enough.
Clean the parts as good as you can with soapy water and scrubbing brush first. Then heat slightly add flux (I use Backers Flux) The flux alone that is in cord solder is not good enough for this job.
You have to heat and add flux 4 or 10 times. If you see black gunk appearing as you are soldering wash with water and brush again. Keep the flux as tight as posable to your working parts or the solder will run over the completed cleaned area.
If you are putting legs on and soldering things like this. Solder on both parts seperatly. Then hold the parts in place and heat until the solder melts together. Hold it there until it has hardened. Then try to pull the legs off. They should bend and not reliese the solder.
So Chuck Clean your job more and use less heat.
It is not something you will learn on the first time you try. I have been useing solder for about 40 years. I am here if you want more help
Albert
