NRV thread size
Discussion in 'Fettling Forum' started by DaveD, Apr 20, 2011.
  1. DaveD
    Hey all,
    I need to make a new pump tube and need to know the thread size of the standard nrv(opti 123, 8r). I assume it is a pipe thread but will need to buy a tap. I don't want (or need) to buy a whole set - just a single tap
    Thanks
    Dave
  2. Knight84
    Hello Dave
    Good question!
    Just so I am clear. Your talking about the non return valve on pump caps right? The barrel/housing with outside threads that screw into the cap.
    I don't know the measurement but I will measure one at the shop once I get out there.
    Jeff
  3. loco7stove
    loco7stove Subscriber
    Hi
    I think he means the thread at the bottom of the pump tube where the NRV screws in , i don't have any idea what size that is by the way, could be a job for SUPER BERNIEDAWG MAN or THE PHANTOM KEROPHILE :thumbup: :D :D :D
    Best regards Stu :D
    PS it'd be nice to know myself :thumbup:
  4. DaveD
    Stu is correct. It is the hole in the bottom of the pump tube that I need to repair.
  5. Knight84
    Ah I get yeah. This is why I asked.
    Opti 123, and 8r's don't have pump tubes.
    What stove do you need a tube for?
    Jeff
  6. payer
    NRV thread size is not a pipe thread. It's a standard metric fine thread M8 X 0.75. Thread in another head of pump tube a place for a pump lid has a metric thread M16 x 0.75.
    Regards Hannu
  7. BernieDawg Banned
    Hi Hannu
    I was just wandering in from the shop after doing some measurements on this. I am afraid that I agree with super-precision machinist Doug Wiese (exeteryak) on the sizes of the NRV components. Here is a drawing he did of the NRV:
    https://classiccampstoves.com/posts/50534
    The drawing is part of this thread here at CCS which may be found in the Fettlers Masterclass section:
    https://classiccampstoves.com/threads/5646
    Both Doug and I measure the thread at 36tpi which is much closer to a metric 0.7 pitch.
    Here is a chart for threads that I find very helpful for this sort of work:
    http://mdmetric.com/tech/tict.htm
    Now, not to say that a M8x0.75 would not work in practice, but I suspect you'd succeed with that size only by deforming the brass threads slightly. Just a heads-up. I think a M8x0.7 would be a closer match to the actual thread, but perhaps just a tad sloppy. Probably still good enough.
    Let us hear how it turns out should you try it Dave.
    Gary
  8. Wim
    Wim Subscriber
    Hi all, I've tried the M8 x 0,75 for cleaning up some damaged threads and found that it came close, but was not perfect. I would only use it in emergencies , like to 'rescue' an otherwise lost pumphousing, but certainly not when making new parts.
    Just my 2€cents!
    Wim
  9. payer
  10. DaveD
    You are right - sorry for the confusion. I am actually repairing an old Aladdin lantern that has a damaged pump tube and noticed there is enough metal (small enough hole) to re-tap it and use an NRV that I have from a 111 fuel tank.
