Stove tank dent repair !
Discussion in 'Fettling Forum' started by gunsoo, May 25, 2011.
  1. gunsoo
    Hi all.
    This is very simple stove tank repair .
    and it is MR.Sun Jongwhan's Korean stove collectors' idea.
    prepare :dent got stove tank,thick wire,soldering
    machine,and strong :lol:
    1.dent place clean up.
    2.whick wire bend to ㄱ shape.
    3.wire and tank with soldering
    4.then pull wire with pinchers.
    5.Remove lead on tank by torch. :whistle:
    *This idea use lantern tank too.
    thanks
  2. idahostoveguy
    idahostoveguy R.I.P.
    Wow. Great idea! It worked! I had thought about doing it but thought it would not work. Nice to be proven wrong. Looks like a good fix.
    Will you be able to get the rest of the solder off?
    sam
  3. gunsoo
    Hi Sam.
    yes it be able to perfect clean body tank with
    torch.but be carfully use torch.
    you must quickly solder off then tank is put in the water. O:)
