Enders military stove "fettle"...
Discussion in 'Fettling Forum' started by Blacksmith1964, May 30, 2011.
  1. Blacksmith1964
    I'm not sure if this even qualifies as Fettling but here goes;
    Got a nice Enders stove today off of Ebay. One corner had a pretty nasty dent in it. As my online name is NOT just a nickname (I really am a Blacksmith, and make copies of Medieval armour as well) I though "hey, I can fix this little dent".
    And so it was with two tools and about 15 mins, she's back in shape!
    The first two photos are of the dent itself from inside and outside. Third photo is of the hammer and the stake tool I used to fix it. And the last two are of the repaired area. I just need to sand it down and repaint.
    1306790870-enders_stove_repair_014.JPG 1306790880-enders_stove_repair_015.JPG 1306790890-enders_stove_repair_016.JPG 1306790904-enders_stove_repair_017.JPG 1306790915-enders_stove_repair_018.JPG
  2. idahostoveguy
    idahostoveguy R.I.P.
    That looks really good. It'll look really nice with paint. Pictures of the finished case when you are done?
    Does the stake tool have a shaft that you are beating on? Just wondering what the whole thing looks like.
    sam
  3. Blacksmith1964
    Well, since you asked, here is a photo of three of my shorter stakes.
    The center one is what I used to repair this box.
  4. idahostoveguy
    Oh, cool! Did you make those tools? Pretty neat. They definitely look like they could do the job.
    Thanks for showing a picture.
    okay, so my next question is: Did you put the case on a soft surface or a hard surface to work it? I've not done any metal work to speak of so I would like to learn. I've done some cutting, brazing and welding but not much of working the metal with hand tools and shaping or removing dents. I've tried but the work never comes out looking too good.
    sam
  5. Blacksmith1964
    Sam, the middle tool "called a mushroom stake" is put inside the dent. Then I hammer on the outside to bring the damaged metal back to it's original form. It's known as 'raising'. If I were to put the piece on a slightly concave surface and use a small ball-pein hammer to change the shape, it would be known as 'sinking'.
    They both have their uses but I find raising the piece gives me far more control.
    And no, I didn't make the tools. I bought them years ago at an auction. I've accumulated a lot more since then.
  6. Big BTU
    Looks great! Really nice job! I like the idea of using a tool like this, I have been using delrin paintless dent removal tools, but it is alot harder I think than using the tools that you have! Those fit into the holes in your anvil right Blacksmith?
  7. RonPH
    Great job on the dent indeed :thumbup: Now I think we have two blacksmith members. Look forward to the finished case. You plan on stripping and repainting it or just a paint over?
    Ron
  8. Blacksmith1964
    BTU, the fit in a "stake plate" which I don't have. However, they fit nicely in my leg vise.
  9. Blacksmith1964
    Ron, yes I want to chemically strip the box (it looks like the last two layers of paint were done by brush) anthen re-paint. I just hope i can find a close enough green to paint it.
  10. RonPH
    Just bring it to the hardware so they can mix it up before you strip it. Then start removing the paint. My Enders was not that bad so a bit of sanding over the rusted areas and painted it close to the original.
    It worked for me :thumbup:
    Good luck.
    Ron
  11. idahostoveguy
    Hey Blacksmith,
    Thanks for the short tutorial on 'raising' and 'sinking'. Now I will be on the lookout for stuff like that at local yard sales, junk stores, hardware shops, etc. I have several cases with similar issues that I've just left alone but now I've got something to hunt for and have some fun with. It's all fun, right?
    Thanks again,
    sam
  12. nzmike
    Why sand or use nasty chemicals when electrolysis is dead easy and and does a solid job? A bucket, a steel plate to fit in the bottom, a car battery charger and a box of washing soda is all you need. Rust and paint are history. If I didn't know how it worked, I'd call it voodoo 8) Sweet job on the case! :thumbup:
  13. pepe
  14. yonadav
    yonadav Subscriber
    Israel
    Well, I might qualify as the third blacksmith here. I completed a basic blacksmith class at Uri Hofi's school a few years back, and occasionally do small blacksmithing jobs. So far I made a hunting knife, a chisel, blacksmith tongs, and a few odd things. I used this skill to make pot supports for a couple of stoves.
    As for paint removal, on non-rusted items I find the chemical stripping faster than electrolysis.
    Yonadav
  15. Wim
    Wim Subscriber
    Ah well, let's make it 4 then, shall we? :whistle: O:) It's over 20years ago now, but I went to school in the weekends to learn restoration techniques. Never done it professionally, but it was very handy in my job as a mechanic at times.
    Wim
  16. Blacksmith1964
    Nice to see so many Iron-Bashers here!
    We may have to have a forum of our own!
  17. hikerduane
    Plumas County, CA
    My neighbor, until a back injury caused him to get Workmens Comp, painted cars in body shops and his brother still does body work/repair. That's as close as I'll come to having metal working skills.
  18. DaveD
  19. Wim
    Wim Subscriber
    Lets call it CBS! (Classic BlackSmiths) :D/ :D/ :D/
    All the best,
    Wim
  20. loco7stove
    loco7stove Subscriber
    Hi
    Nice work on the stove repair :thumbup: :D cant beat getting the steel up to the greasy stage for a bit of fire welding ,not for the faint hearted though :shock: :thumbup: :D
    Keep up the good work :thumbup: :D
    Best regards Stu :thumbup: .
