Hi I have available a limited number of 100ml stove/lamp priming bottles. More may become available later depending on demand. 130mm long 42mm Dia. These are as you can see labelled "Meths" with a skull and crossbones warning. These are proper plastic permanent labels, the print is solvent resistant. Other text can be used PM me (sorry only black). The top allows you to dispense your meths without removing anything, just twist and squeese and twist to close again (similar to valvespout only in HDPE). Price is £1.20 +P&P Valve open. Valve closed. Cheers Gary
