Optimus No.5
Discussion in 'Optimus No:5 (inc. S & J)' started by Admin, Aug 23, 2012.
  1. Admin
    Admin Courtesy of Iani
    1345748254-IMG_7627_opt.jpg 1345748283-IMG_7628_opt.jpg 1345748310-IMG_7629_opt.jpg 1345748329-IMG_7630_opt.jpg 1345748366-IMG_7631_opt.jpg 1345748384-IMG_7632_opt.jpg 1345748404-IMG_7633_opt.jpg 1345748424-IMG_7634_opt.jpg 1345748463-IMG_7635_opt.jpg 1345748483-IMG_7636_opt.jpg 1345748517-IMG_7637_opt.jpg 1345748548-IMG_7638_opt.jpg 1345748615-IMG_7643_opt.jpg 1345748635-IMG_7644_opt.jpg 1345748663-IMG_7639_opt.jpg 1345748698-IMG_7647_opt.jpg 1345748734-IMG_7645_opt.jpg 1345748763-IMG_7646_opt.jpg 1345748792-IMG_7648_opt.jpg 1345748822-IMG_7641_opt.jpg
  2. yonadav
    yonadav Subscriber
    Israel
    Magnificent, as usual!
    Yonadav
  3. kerophile
    Hi Ian, Nicely presented Optimus No.5.
    I reckon it probably pre-dates 1962 and the formation of the PTC, since most components apart form the "Primus" spirit cup appear to be marked Optimus, Sweden, with the additional Upplands Vasby mark on the base of the tank.
    I wonder if the spirit-cup was a later addition?
  4. Admin
    Hi Yonadav
    My school reports always said I could do better !
    Still trying.
    Hi Kerophile
    Spirit cup did throw me a bit. Thats why I included it in the pictures.
    I thought maybe, made after Optimus had taken Primus over, as the riser tube and spirit cup and burner, had little use.
    I then had a look at the 1957-58 catalogue, and it is probably from that period.
    The burner itself is not marked Optimus underneath.
    As this particular stove is not in the SRG, I thought it was well worth adding.
    Regards to you both
  5. Garth
    Ive just picked up one very similar from a second hand shop uppl vasby stamp on base optimus burner and a primus burner cap which try as i might i cant remove must have been hammered on, only lightly used wont take a lot to get going as the pump works fine​
  6. threedots
    threedots New Zealand Subscriber
    @Garth . Try preheating the burner to operating temperature like you would if you were to start it. Then with a rag, quickly remove the burner cap before the cap and burner begin to cool down.
    Hope that works. John
