Svea No:53 Range
Discussion in 'Svea No:53' started by Archivist, May 19, 2008.
  1. Archivist
    Archivist Archivist
    Courtesy of Finn Hjelmerud
    Could be bolted to a No:52 to make a double burner range.
  2. marksheean
    I think my friend had one of those but at the end just gave it to someone. Never found out how it ended up.
  3. Sedgman
    Sedgman Subscriber
    Victoria, Australia
    I believe this model is actually a Svea 153, and the bolt is obscuring the one. If you look at the Gallery for model 152 you will see the connection. They all belong in a series from 150 to 155 depending upon configuration.
    Iain Sedgman
  4. Sedgman
    Sedgman Subscriber
    Victoria, Australia
    Following further investigation by Tony Press and myself about the SVEA and Companion range stoves I have changed my view on this and consider this is in actuality a SVEA 53. Just for the record.
    Iain
