Howes & Burley Corona no 1 ?
Discussion in 'Stove Forum' started by Håvard Kvernelv, Mar 25, 2026 at 1:33 PM.
  1. Håvard Kvernelv
    Narvik, Norway
    Hi, all.
    I have recently added this stove to my collection. I intend to present it in the gallery, when cleaned up properly.
    But, first I’d like to identify it.
    Can I assume it is a Howes & Burley Corona No. 1?
    It has the filler on the side, it is clearly marked «CORONA», but without any number.
    No text or markings on air release screw, pump or pump tube lid. The filler cap is marked «CORONA».
    The pump and leather arrangement is normal type, but the pump rod has a damper spring.
    I think the burner is the one in the Pifco ad identified as c504:
    https://classiccampstoves.com/threads/1925-pifco-catalogue.186/
    Some part(s) is missing on the burner. I think the outer flame spreader that I have is original. But what does the inner part look like on this uncommon burner? The burner hexagon is stamped with an «O» or «0»?
    IMG_3766.jpeg IMG_3767.jpeg IMG_3768.jpeg IMG_3769.jpeg IMG_3770.jpeg IMG_3771.jpeg IMG_3772.jpeg IMG_3773.jpeg IMG_3774.jpeg IMG_3775.jpeg IMG_3776.jpeg IMG_3777.jpeg
  2. OMC
    OMC United States Subscriber
    I defer to Ian @igh371.
    Havard,
    Thank you for posting, this is fantastic. Congrats!
    re your: "Can I assume it is a Howes & Burley Corona No. 1?"
    Given you have looked and there is not a model number anywhere on tank, i too think it is safe to assume yours, with orig roarer burner was sold /shipped as a model No.1.
    re your: "I think the burner is the one in the Pifco ad identified as c504:
    *It is a VERY RARE burner and
    what you show us is an exact match, i have to agree, yes.
    re your: "I think the outer flame spreader that I have is original.
    Yes, your post is convincing your roarer is original missing orig flame spreader.
    BTW my initial gallery search has your burner as the only known example. I doubt the cat. illustration /image shows enough to make a DIY replica flame spreader [just a guess: yours a 1st version, that was maybe discontinued].
    ^^^ WELL DONE :clap:
    As mentioned i defer to Ian.
    His Howes & Burley Corona No.1 - 1921-2 (posted Jan 2023) with info available at the time. Comparisons can be made (previously unavailable), for best guess which example yours vs his to suggest which might be earlier /later. AND Ian might now add current thoughts re his roarer.
    Marking on burner? I had impression his 4-tube roarer was also likely original?
    Additionally i'll just note re dating: the "1925" catalog, consider that year might move fwd / back AND as always outdated details are often included in catalogs /brochures (esp. 3rd party).
    thanks again, carry-on
  3. Håvard Kvernelv
    Narvik, Norway
    Thank You @OMC - it seems that I have found the closest match in the CCS. I should add that it is quite amazing that the stove - and trivet - has survived the 100+ years in such a shape. I will try to fire it with some different flame spreaders.
  4. Håvard Kvernelv
    Narvik, Norway
    It’s burning :-)
    I simply cut the top part of a normal (Primus 210 size) roaring burner and placed on top.
    It sits loose and must be fixed in some way to be used, I guess.
    But as a first test, its not bad. Strong flames, a bit yellow due to not-so-clean fuel.
  5. igh371
    Durham
    @Håvard Kvernelv What a wonderful discovery. Not just the stove but especially the burner. A real moment of revelation. I feel sure that you are correct in making the link with the c504 burner in the Pifco advert. And I think that your inspirational make-do with the cut off roarer top is far closer to the original than you might have imagined. Just look at the roarer on Howes & Burley's 1 pint 'Picnic No.2' stove here: Howes & Burley - Corona No.2!!!
    @OMC
  6. Håvard Kvernelv
    Narvik, Norway
    Great - that seems to be my «missing part». It appear to be stuck tight within the outer flame spreader. I’ll try to find a similar solution.
