Minor fettle on a PT-1
Discussion in 'Stove Forum' started by kk1992, Apr 2, 2023.
Repaint or preserve?
  1. Strip the paint and recoat
    7.7%
  2. Leave as is, keep it in original condition
    92.3%
  1. kk1992 Germany
    Germany
    Hi all,
    a few weeks ago I bought an old soviet PT-1 stove on a well known auction site.
    Instead of my usual procedure to clean down to metal and repaint, I choose to try to preserve the status quo.
    A first burn test revealed that the tank was filled with two-stroke mixture and that the stove produced a weak flame with excessive soothing.
    So I proceeded to tear down everything.
    Here's a picture of the old wick alongside the new one:
    9274CF8A-5AEC-4338-AC7C-68E63613B750.jpeg 0302825F-B50F-465C-B23B-DE84F63E40BD.jpeg 0D2EB681-226F-4E6C-B398-BF9213D6BD6F.jpeg
    I put the case in a mild cleaning solution and put some rust converter on the spots where the old paint was worn. After I cleaned of the rust converter, I applied two thin layers of clear coat:
    The old gaskets were all either hardened out or turned into a sponge like texture. So I replaced them with viton/fkm. Interestingly they used a rubber piece to seal the spindle. Graphite foil seemed to be a proper replacement.
    After putting everything together, using a soap block as threadlock, I test fired the stove.
    Methylated spirits (Brennspiritus) to preheath, alkylated gasoline (Aspen 4) as fuel.
    This time I got a nice, clean burning, flame. Stable burning from low simmer to full throttle.
    408F815D-9BCD-4CF2-8E46-B38246C25F27.jpeg 66F91762-ECE8-4A22-B354-C0FF0481B924.jpeg CC411646-A751-427A-8F93-C71E85D4E5FA.jpeg
    All in all one can see that this stove was produced in a very crude manner. Loose tolerances, sharp edges, questionable paint. But from the engineering persepective it is a nice workhorse of a stove. Albeit not as beautiful as a genuine Optimus 8R.
    Now I just need to decide:
    Leave the stove 'as is' or strip the paint and apply some modern coating...
    regards from germany,
    kk1992
  2. bbsteinle
    bbsteinle United States Subscriber
    Spokane, WA USA
    The original paint looks pretty decent to me.
    Basil
  3. ROBBO55
    It's cleaned up nicely, congratulations :thumbup:
    I would leave the stove as is at this point.
  4. CW
    CW United States Subscriber
    no rust the case looks good keep it original
  5. Harder D. Soerensen
    Denmark
    It can only be original once - In that condition - I’d keep it that way.
    I’ve had two of these - (robust and quite powerful!) sold them in weak moments over time ](*,)
  6. ulysses
    ulysses Subscriber
    Manasquan, New Jersey USA
    Yes, leave the paint, it looks OK, and it takes you back to the USSR (you don't know how lucky you are.......)
  7. Doc Mark
    I got it, Ulysses! Nicely done, my friend!
    - Doc
  8. kk1992 Germany
    Germany
    Ok, this seems to be a settled matter.
    I'll leave it as is (even if just for the beatles reference) :clap:
