111T for the family?
Discussion in 'Stove Forum' started by Litch, Nov 4, 2014.
  1. Litch
    Thank you, Andy!
    I'll give it a try this weekend - with pix :)
  2. alnl1996
    alnl1996 Subscriber
    Ontario, Canada
    That's great advice, I always set the needle low to the point that fuel will leak out after I closed the valve after I pressurise the tank. Not lit of course.
    Then I reinstall it again with one less click.
    Then I know I have full range on the burner.
  3. Ray123
    Ray123 Subscriber
    New Hampshire, USA
    Hi Litch,
    The Optimus catalogues spec the 111 as having a boil time of 3-4 minutes for 1 liter of water and the 8R as 6-7 minutes for the same job. Of course these are laboratory results at room temperature conditions. I haven't been able to get anywhere near these results.
    Today for an experiment I fired up the 111T to see how long it would take to bring a liter of water to a boil. The temperature is -2C with sunny but windy conditions and the water was 8C from my tap. It took double preheats to start the stove. After 15 minutes it still wasn't boiling and I ended the experiment with the water around 90C.
    Even indoors I can't boil a liter in 6 minutes. I believe my stove runs as it should and I even tried the same test with a Primus 5 and a couple different pots. Your results with 7'45" for an outdoor boil seem more than reasonable for winter conditions. I don't think you have much to be concerned about but let us know how things go.
    Ray
  4. Litch
    Thank you all for your input. I must admit that my boil test was a while ago (September) at maybe 18°.
    I'll try again on the weekend and will let you know.
    Thx, Peter
  5. Litch
