530
Discussion in 'Stove Forum' started by THE PUNISHER, Jan 7, 2010.
  1. THE PUNISHER
    Kentucky
    Hello,got a 530,i can not get it to hold a flame,i replaced the o ring in the fuel cap,i pulled the pump the leather looks good it seems to hold pressure but it is not,any help thanx
    :cry:
  2. brassnipplekey
    Pump it up & dunk it in a bucket of water :-)
    Its the Pump & Dunk test ... The bubbles will show you where to fettle.
    Nick
  3. lanevitt
    lanevitt Subscriber
    Hi The punnisher (The punnisher????) hmm (that reminds me to never leave my thong in the tumble dryer, two sizes too small now!! oh well gotta keep wearing them, they were a christmas prezzy in 1996.)
    When i replaced the O ring on the filler cap, the old one was a pain to remove, had to make sure every bit was cleaned off back to clean brass.
    A little bit of silicone grease on the seal to finnish.
  4. THE PUNISHER
    Kentucky
    off to the kitchen sink...... :shock:
  5. THE PUNISHER
    Kentucky
    got it light it is spurttig/lol,but itz going the fuel knob is hard to turn i guess when it heats up..
  6. Knight84
    Hello,
    The fuel control knob is hard to turn because the packing nut on the there side of the knob is too tight. You can loosen it a little and then check to see that it still seals.
    Jeff
  7. THE PUNISHER
    Kentucky
    let me check,i have been polishing like d day is coming...
    got it looking bout brand new,it has held pressure for about 3 hours..
  8. Lance
    Lance Subscriber
    Northwestern Illinois
    530 'ey. hummmm. What year?? Should read something like B46 or such on the fount.
    As i'm sure you know, these were made after the war.
    lance
  9. THE PUNISHER
    Kentucky
    got it thanx.. :thumbup:
  10. THE PUNISHER
    Kentucky
  11. THE PUNISHER
    Kentucky
    alright i took the 4 screws that hold the burner to polish, curious if i put the side with the writing on correct.. :-k
  12. Littledre
    Hello P, there is a good diagram and parts list HERE for a 530. Is your stove still spitting and spluttering?
    A46 stands for when it was made, the first 6 months of 1946 if you did not already know.
  13. Lance
    Lance Subscriber
    { A 46 } Jan to June 1946. not sure about your question concerning the writing.
    lance
  14. THE PUNISHER
    Kentucky
    thanx is it one of the first 530's?
    i took the burner off to polish the top of the fuel tank,i took 4 screws loose,i am not sure if i got the 4 corners on right,the writing on the legs?
  15. Littledre
    P, I have just had a look at one of my 530's. Where it says "PAT NOS ########### AND USE VAPORISER NO###" this should be the first strut after the filler cap as you look at it but I do not think it makes a lot of difference.
    My one is an A46 as well
    Den
  16. DavidOR
    Punisher....Go into the Stove Reference Gallery on the site here and and check out a couple of the photos posted in thre for the 530's. The one subtitled "bullet stove" (I think) has a couple close-ups of the support legs that have the imprinted directions on them. You should be able to tell if yours are correct from the photos.
  17. THE PUNISHER
    Kentucky
    hmm, thanx
    that is facing the control knob the dark one it is to the left..
  18. Littledre
    The plain pillar to the left of the fuel filler cap.
  19. THE PUNISHER
    Kentucky
    got it thanx........... :clap:
  20. anlrolfe
    Louisville Kentucky, USA
    Could be H20 in the C8H18??
    Try to drain/suction it out and refill with fresh C8H18.
    If that doesn't work, perhaps its time for a new vaporizer or vaporizer screen.
    Good luck,
    AR
