Any ideas?
Discussion in 'Stove Forum' started by Aaron1980, Mar 29, 2022.
  1. Aaron1980
    Aaron1980 Subscriber
    Hi just a quick question. Does anyone know what type of Primus this is?
    Thanks I’m advance
  2. Afterburner
    ±Finland°
    Looks a bit (or quite much) Primus DIY.
  3. Aaron1980
    Thank you. the more I was looking at it the more confused I was getting.
  4. Afterburner
    ±Finland°
    Those regulated burners are 'worth of money' / 'very usable' if they are not modified nor damaged for some reason.
  5. snwcmpr
    Parts put into a case.
  6. pau-i-amor
    pau-i-amor Subscriber
    17190 Salt, Catalunya
    I can't see any conexion between burners and tank... :-k
    Parts put into a case. I think so too.
  7. Scrambler
    Australia
    Despite the comments of knowledgeable people (and this comment by a grommet) I think it's a functional stove. There is nothing to suggest the parts are set up for the photo, but the burners are exactly symmetrical. The smoke deposition on each side of the fount is symmetrical. It was used in this setup. Therefore there are pipes connecting even though I can't see them.
  8. snwcmpr
    I cannot see any 'connection' on either of the burners.
    The tank looks like a stand alone item.
    Parts in a case.
  9. z1ulike
    It looks like Primus 14 parts. I own two of them that are featured in the Reference Gallery here.
  10. Kiwi NZ
    Kiwi NZ Subscriber
    New Zealand
    It is definately someones creation. I have blown the picture up and can see that the legs are sitting on studs that are possibly fixed to the case. I am fairly sure that I can see a connection for each burner, plus the scorch marks on each side of the tank suggest that it has been used.
    Good luck
  11. Afterburner
    ±Finland°
    I would think that stove in working even that design is a bit rough. Maybe hole(s) has been drilled on side or bottom of the stove and fuel tube to burners has been attached into hole.
  12. OMC
    OMC United States Subscriber
    AB, this thread has been edited as per site policy, my above comment was deleted.
    I'll repeat, I am glad to see you're active with us again.
    kiwi is "...fairly sure that I can see a connection for each burner.."
    makes him a better man than i gunga din .
    If so, for those seeing working frankie, there you have it.
    I'd say more but might get deleted again.
  13. snwcmpr
    Primus 14 burners does look right. The tank looks different from Ben's tanks.
  14. z1ulike
    Optimus 22 prototype maybe?
    Ben:D/
  15. snwcmpr
    Yes, that's it. Very rare.
  16. Kiwi NZ
    Kiwi NZ Subscriber
    New Zealand
    @OMC have I offended you with my comment on this post? If so pm me and let me know what the problem is.
  17. OMC
    no not at all, no hidden msg there.
    you "fairly sure that I can see a connection for each burner.."
    i looked closely, looking for that, did not see that. couldn't see it nor envision it.
    you did better.
    I can only guess other stovies weighing-in could not see it either.
    I mean no offense.
    I adopt your position, conceded your point.
    nothing else sorry if left a different impression (does happen, my bad)
  18. Afterburner
    ±Finland°
    @OMC I saw @Aaron1980 post that is deleted. I hope that he will be able to proceed as he has planned...
    I was not able to see burner feed tubes but I believe that burners have worked since there is quite much soot around the case. Build is 'rough' so maybe feed tubes are also "get it working and don't worry how it looks" implementation.
  19. snwcmpr
    A live auction post was deleted, not sure of what other posts were deleted.
  20. Kiwi NZ
    Kiwi NZ Subscriber
    New Zealand
    Thanks @OMC, I copied the image to file as a jpeg then opened it in MS Photo Viewer.
    I magnified it until almost pixilation stage.
    The "shadows" on each side that I thought may be feed tubes looked remarkably similar and symmetrical to each other.
    I imagine it is pretty rough construction, if that is what it is, the square headed bung screwed into the burner tube hole is
    and indication of the degree of professionalism.
    I would purchase this in a heart beat if it became available in a locality close to me, some good parts there.
