Beatrice Logo?
Discussion in 'Stove Forum' started by MARK HOLMAN, Oct 20, 2016.
  1. shagratork
    Here is Blueflame's logo with a transparent background.
  2. shagratork
    Here is the same image with the vertical lines more vertical.
  3. Doublerat
    Leicestershire
    Thanks to Blueflame and Shagratork for their work. The logos for me now look perfect
    I agree with Blueflame that colour rendition with translucent inkjet printed waterslides will not be true to the original, and it maybe that the greater opacity of white waterslide paper would help and be a better choice for dark backgrounds
    https://www.ebay.co.uk/itm/Water-Sl...hash=item2a5684b809:m:mWYV0k2-KpXw6nP3N5Ll8Ug
    There are specialist decal printers out there who may be able to overcome all of these problems, particularly wth replicating the metallic colours, but I guess at a cost that for me is not warranted by the value of the stove. Not that I am tight you understand........
    http://wessextransfers.com/custom-decal-printing/
    My hope is to be able to produce something as close as practicable to the original to make to stove look more complete
    Looking forward to hearing again from Geoff on the correct dimensions and once the Beatrice is all back together I will give the waterslide a go and let you know how I fair
    Thanks again to all for the fabulous response on this one
    Phil
  4. Blueflame
    Blueflame Canada Subscriber
    Montreal Canada
    There is waterslide paper made for laser printers also. This is better than inkjet as the colors will not run. Those who have a color laser printer (or can get use of one) will get better results. With inkjet you have to spray a clear coating to get a durable decal, laser does not need a coating (to my knowledge).
  5. Matthias
    Matthias Subscriber
    Germany
    Hi all, i could offer you to draw the picture in vector graphics like my other pictures in the decal section here.
    Mat
  6. Matthias
    Matthias Subscriber
    Germany
    A few years ago i made some Tilley decals with golden background in this way:
    Printing on clear decal paper, apply on golden self-adhesive foil and stick on the lamp.
  7. Tony Press
    @Matthias
    I do believe that I have some of your Tilley decals and they are excellent!
  8. shagratork
    @Matthias
    Your computer graphic skills are much more advanced than mine.
    In fact my skills look pathetic!
    If you are willing to spend time on this project, it will be much appreciated.
  9. Doublerat
    Leicestershire
    @Matthias
    Redrawing the decal in vector graphics sounds like an awful lot of work (I tried with vector magic but the results were not good. But then I don't know what I am doing!). So if you are willing to devote the time it will be very much appreciated
  10. Matthias
    Matthias Subscriber
    Germany
    Tony, i remember, the Tilleys has gone to Tasmania!:content:
    The first try....:
  11. Doublerat
    Leicestershire
    Wow, that's impressive!
  12. Kiwi NZ
    Kiwi NZ Subscriber
    New Zealand
    Wow is not enough, double WOW!! the vertrical lines are not supposed to be vertical they are at the same angle as the sides of the base of the stove/heater.
    This photo is take square on
    From the top left hand point of the B to the top right hand point of the E is 101mm. from the bottom point of the B to the bottom point ot the E is 105mm.
    The height of the B left hand point to point is 22mm The height of the E right hand poiunt to point is also 22mm.
    The black line above reg trade mark is point to point 92.5 mm as best as I can read it. the points are not well defined.
    Any other measurments that may be needed please let me know.
    This stove is one many projects that I have waiting for me.
    Geoff
  13. shagratork
    @Geoff Chirnside
    Thanks for the observations about the non-vertical lines.
    I first thought it was because of the camera angle.
    Obviously you are absolutely right.
    Here is the image made by @Matthias with a slope introduced and on a transparent background.
  14. Blueflame
    Montreal Canada
    I used @Matthias file and printed these on a clear decal sheet. The colors are surprisingly good. Are the dimensions acceptable?
  15. shagratork
    Wonderful, collaborative work. :clap:
    All I need now is a Beatrice stove!
  16. Blueflame
    Montreal Canada
    @shagratork this was made on an inkjet printer....your stove will be made on a 3D printer.[-o<
  17. Rangie
    Rangie SotM Winner Subscriber
    10/10, this is why I really like this forum, an international cooperation/collaboration of talented enthusiasts! :thumbup: :clap:
    Alec.
  18. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    Fantastic quality of work! Impressive how quickly it all happened, too.
    ....Arch
  19. Matthias
    Matthias Subscriber
    Germany
    I thought the same....
    Are there any other reliable measurements?
  20. Kiwi NZ
    Kiwi NZ Subscriber
    New Zealand
    If you compare Shagatork's photo and mine you will see that they are different versions of the same decal and are no doubt from different times of production.
    The obvious differences on mine are that the centre cross bar of the E's do not have the points, the o in No is elongated and the flourishes on the E's T and C
    are different in shape
    Mine
    Shagatorks
    If you start looking close you will see other proportions are not quite the same. My measurements are reliable but may not be entirely relevant to the image being produced.
    Hopefully someone that has the same version can add measurements that may be more helpful.
    Geoff
