Cleaning burners?
Discussion in 'Fettling Forum' started by nmp, Aug 28, 2011.
  1. nmp
    nmp SotM Winner Subscriber
    I have just picked up a biscuit tin Optimus 45 and a chrome veritas picnic stove and I want to know the best way of cleaning the very black burner heads and also do the insides need cleaning out? If so how? I have read some threads that involve the use of citric acid is this ok? as another I have read, talks of it doing damage? What about carburetter cleaner or similar ie redex post.
    TIA
    Nick
  2. loco7stove
    loco7stove Subscriber
    Hi Nick
    To clean the burner heads i heat them up with a propane torch ( they need to be a dull red in colour, turn down the light to make sure you don't over do it ) & quench/place them quickly but gently in a citric acid solution ( desert spn of acid crystals per pint of hot water dissolved ) deep enough to submerge the burner in, the burner will spit,bubble & blow steam out of each end be carefull :shock: . This cleans the crap off inside & out
    Do this as many times as you need to to clear out the inside burner tubes then i leave the burner in the hot acid for an hour or two this will make the burner bright again , wash in clean water & blow out the tubes to clear out any residue & clean the outside with a brass bristle brush, should come up a treat.
  3. Wim
    Wim Subscriber
    I usually immerse the burner into some (cheapo) vinegar for half an hour first, then do the heat&quench (in water) a couple of times (depends on how dirty the burner is) followed by another vinegar bath. Don't forget to remove the jet first! When all the carbon is gone, the outside can be polished to your own liking.
    Best regards,
    Wim
  4. yonadav
    yonadav Subscriber
    Israel
    Hi Nick,
    First, you must observe the golden rule "if it ain't broke, don't fix it".
    Test fire your stoves, and if the flame is right, don't bother with the burner insides. Still, a flush with carb cleaner cannot hurt. Do make sure to remove and clean the jets.
    For the burner head outside, I soak it in citric acid for 10 minutes or so. Then I clean the head with a toothbrush soaked in detergent. Don't soak for much longer time, as the acid slowly eats away the metal.
    yonadav
  5. loco7stove
    I meant to say take the jet out first though :doh: .I have tried carb cleaner & this works on soot & gum but carbon is another kettle of fish this takes a bit more of a clean.
    Stu :thumbup:
  6. nmp
    Thanks gents that gives me a few avenues of attack. Where do I get the citric acid? are we talking of anhydrous? if so how is it marketed?
    Tests firing will be first, how do I know if they need an internal clean?
    Sorry about all of the basic questions!!
    Nick
  7. loco7stove
    Hi Nick
    Go to your local independent chemists & they sell it in 100 250 or 500grm packs, just tell them its for cleaning a kettle or coffee machine out of scale :D .
    Use the same crystals to make cleaning gel with wallpaper paste & warm water to clean up your brass tanks too, works a treat :thumbup: .
    Best regards Stu :thumbup: .
  8. nmp
    Tried Boots this afternoon they do not stock it any more because you can make bombs out of it so I will try the local independent one later.
    Had a go with lemon juice and vinegar and got a fairly good result.The acid should be impressive.
    Thanks
  9. nmp
    Talking about cleaning the inside is an orange red and green flame a sign that a de coke is in order?
  10. yonadav
    yonadav Subscriber
    Israel
    A photo might help us answer that.
    Yonadav
  11. Trojandog
    East Sussex
    Boots is a waste of time nowadays unless you want shower gel or cough drops.
    If everywhere stopped selling stuff that you can make bombs out of there would be little left to buy. No more BBQ charcoal, no more fertiliser for the garden, no more sugar.
    If your local chemist doesn't have any then any homebrew shop will.
  12. yonadav
    yonadav Subscriber
    Israel
    Here in Israel citric acid is sold in food stores and supermarkets as "lemon salt".
  13. nmp
    Thanks everyone I managed to get 150g in Wilcos brewing section which will tide me over until I get an internet order together.
    What strength of solution should I use ?I may have had the first lot too strong some bits went a bit pink!!! :doh: :oops: I used a hot solution and it cleaned up very quickly!
    I hope I have not ruined it!!
    will post pre clean up flame photo tomorrow Yonadav
  14. yonadav
    yonadav Subscriber
    Israel
    I use 1/4 teaspoon in a cup of warm water. You should adjust the strength and time by trial and error - this is not exact science.
    A bit pink is normal. It will get the regular brass color after some cleaning with detergent and, if you like, polishing with Brasso.
  15. nmp
    Yes by the sounds of it I was a bit heavy handed with the crystals! It did fizz a bit !!!!!
    Next time I will take it easy and cut down to 1 spoon full to a baked bean can of hot water from 3!!
    Mind you it was quick. :oops:
  16. nmp
    Here is a picture of the flame pre clean up Yonadav
    what do you reckon? I have not fired her up since the clean up but will do so tonight and let you Know if its better. 1314720521-DSC_7188.jpg
  17. nmp
    here is the burn after the clean up what do you reckon looks good to me! 1314741394-DSC_7206.jpg
  18. nagant
    Nice stove and a good burn!
  19. nmp
    thanks Its gong well now!
  20. yonadav
    yonadav Subscriber
    Israel
    Perfect flame, Nick,
    Congratulations on a well done fettle.
    Yonadav
