Coleman 460G converted to kerosene
Discussion in 'Stove Forum' started by hikerduane, Mar 11, 2023.
  1. hikerduane
    Plumas County, CA
    Per @presscall, in a old thread, set this up for kerosene. With more pressure this morning, running hotter than yesterday when photo was taken, even the grate got red hot today in the inner part. Need to fix a leak out of the genny tip as it sets in the end of the genny too loose.
  2. Cajuncook1
    Cajuncook1 United States Subscriber
    DFW
    Good show Duane. Once I get my Coleman 457G going. I might like to try kerosene in the stove. I like the safety aspect of kerosene as well.
    Do you have the link to Presscall's post how he used kerosene in a 457G stove?
    David
  3. hikerduane
    Plumas County, CA
    David, I can't find that topic, I posted on CCF the parts needed for a 460. I put my list in my parts box in the garage. Stinks like the Coleman marine stove, fire it up outside.
  4. Scrambler
    Australia
    Coleman Handy Gas Plant, No.457
  5. presscall
    Odd, I don’t recall mine doing that. Blowtorch to prime, right? A lot of metal to thoroughly get up to vapourising temperature, or there’ll be yellow tinges to the flames and they’ll put out a smell.
  6. hikerduane
    Plumas County, CA
    Still working on sealing the genny tip, a bit of a candle flame. I did notice it takes quite a bit more preheat than even a Tilley. Lots of metal to get hot. I agree, even the burner needs to be heated good.
  7. Lantern
    Lantern Subscriber
    Nevada
    Hi Duane, I bet that glare from outside your garage is from a little snow right? Charlie
  8. hikerduane
    Plumas County, CA
    Hi Charlie, yes, lots of snow, not quite as much as Doc Mark.
  9. presscall
    Ah yes, you’d mentioned that. It’ll be what’s causing the smell.
  10. Cajuncook1
    DFW
    Thanks for the link Scrambler
  11. Crater Eddie United States
    Southern Illinois, USA
    Looks like you have it running well! Crongrats!
