Coleman Apex pump leak from fuel spindle
Discussion in 'Fettling Forum' started by JohnL, May 17, 2022.
  1. JohnL
    Australia
    Thanks to @presscall teardown of his Apex was able to find the brittle o-ring causing my Apex pump to leak.
    Yes, it's got the crack but it wasn't leaking there, rather from the fuel valve on/off.
    Replaced this with a 005 viton type (used in the 550 also) and leak solved!
    Simmer to full blast on an Apex 450A700 (04/95) burner.
  2. Daryl
    Sunny SoCal Grand Terrace
    Good job fixing that fine stove. I had one that had cracked at early age , but never leaked too.
  3. JohnL
    Australia
    Thanks @Daryl
    It's crazy, everything on that stove set is aluminium, pressed metal or brass (even the level adjuster is brass!) but the pump housing is a crappy plastic. A real shame because if that housing was metal, these things would just go and go.
    Simple user serviceable parts too.
    I'll keep using it until I can't.
