Good morning all, I have recently fettled my 9060 stove, and I’m not sure I pushed the cotton wick with the wire in the fuel pick up tube correctly. The burner will ignite, but, the power is very weak with good pressure in the tank and then the flame will lift off the burner and go out. Maybe the wick hasn’t had enough time to soak up enough fuel, or the wick isn’t pushed in the fuel tube enough or it’s because I forgot the metal mesh? . Your help and teasing is welcome. WH
Hi William, This is because you inserted the cotton wick to tightly, try to pull it a little bit out, it helps to deliver the fuel faster.
