Fettlebox SRV tool
Discussion in 'Fettling Forum' started by Longilily, Nov 5, 2015.
  1. Four Smokes Wallup
    Canada
    Yes, however there is no substitute for a proper hardened penta tool which is out of stock.
    I am quite aware that loctite has been used on the SRV threads and either chemical means (acetone, alcohol or other suitable solvent) as well as heat to destroy the bond.
    Currently, BernieDawg is viewed as a last resort, and failing that, I may just wind up forging the hardened penta wrench myself as a least productive use of my time.
    Current hex socketed SRV brass Optimus tank caps are a least expensive option, but, are not period correct for the penta socketed SRV Optimus tank caps used with the mini pump, or the ordinary penta socketed SRV caps not used with the minipump. Burglarizing Optimus physical tool historic archives is unrealistic.
    Let’s see, O1 or similar tool steel along with shaping, blacksmithing tools and a proper high temperature, digitally controlled gas forge... Wouldn’t be the first time I’ve had to make things from scratch. :twisted::twisted::twisted::roll::shock::?:-k
  2. Four Smokes Wallup
    Canada
    Looks like Good Fortune smiled on me. :D On with the holiday season fettling!
