Fettling materials & tools - what to use & where to find them
Discussion in 'Fettling Forum' started by Spiritburner, Aug 12, 2009.
  1. Marc
    Marc Subscriber
    Oregon, USA
    I've used the Rustoleum rust converter primer. Worked great.
  2. rchilso United States
    USA Georgia
    is there anything wrong with using throttle body carbon remover such as "GRC throttle body and valve carbon cleaner", to remove carbon buildup in the vapor tubes?
  3. Tony Press
    @rchilso
    I use carburettor cleaner for cleaning vapourisers. You sometimes get interesting colours on first light up, but it’s fine. Pipe cleaners are useful, as well.
  4. redspeedster
    County Durham
    Mr Muscle foaming oven cleaner is our local mechanics weapon of choice for cleaning gummed up and coked up components. May be worth a try.
  5. Marc
    Marc Subscriber
    Oregon, USA
    Make sure the cleaner isn't chlorinated. You'll get more than funny colors when you first fire it up.....
  6. Ed Winskill
    What Marc says. I had several cases in the mid-1980s involving folks that put torches to chlorinated-hydrocarbon paint strippers to 'speed the process up'. The result is the production of phosgene, a poison gas used on the battlefields of WWI.
  7. rchilso United States
    USA Georgia
    I don't heat any fluorocarbon based cleaners. I enjoy being able to breath easy. i would highly suggest using an air hose with nozzle to dry off any cleaner before reassembling the stove prior to firing. the old 111 chloro based fire extinguishers killed a lot of people before they were abandoned.
  8. Archie MacIsaac Canada
    Nova Scotia, Canada
    I know eh.. it's my first time in here too. Thanks for the knowledge posted and for the direction..
  9. snwcmpr
  10. rchilso United States
    USA Georgia
    Not too good. I had to get one from quiet stove that looked like a 5 pointed Trox bit , but I was able to get the screw removed and fix the srv.
    I'm waiting for the metal washer for the stem seal to arrive from Basecamp sports to fix the stem seal issues, (the stove leaked around the control valve stem), this had when I bought it. The metal ring behind the graphite packing was missing
  11. snwcmpr
    @rchilso
    Thank you. So, I will pass on the Peerless tool.
    The Quietstove tool is known to round the 5 sided hole.
    I like the tool Berniedawg made.
    Ken
  12. rchilso United States
    USA Georgia
    I'm still looking for a correct tool for the SRV seeing as I have other stoves but the fettle box doesn't carry the Penta tool anymore and eBay wants 32.00 plus shipping for a t-handle version.
  13. Mcbhaine United States
    Wilmington
    Sheepsfoot
  14. snwcmpr
  15. Sellig33
    Stripping pliers
  16. Gurgle
    Gurgle United States Subscriber
    PNW, US
    Sheepsfoot is a good name for these soldering assist doohickeys. They’re the bee’s knees for removing and seating seals, thanks to the dual curved points, tempered and sharp. Found at Radio Shack too long ago.
  17. Gurgle
    PNW, US
    This hastily cut open doorknob with jaggedy-pointy bits and flat-scrapey bits has been handy for cleaning burner washer sealing flats and annular groove with the burner threads safely tucked out of harms way inside. The chunky knobular shape is as easy to manipulate as, well, a doorknob.
  18. Tony Press
    A “sheepsfoot” tool has a very specific use.
  19. snwcmpr
    Sheepsfoot. A word by itself.
    It is also a shape of a knifeblade. I am sure the word, by itself, has other meanings.
  20. Gurgle
    PNW, US
    Seized upon it as cue to contribute. The above soldering forks could also be described as cats paw, pig hoof, lobster toes… cockroach mittens?
