For those of us who are not comfortable with fixing lipsticks
Discussion in 'Fettling Forum' started by Remus1956, Mar 5, 2025.
  1. Remus1956
    Los Angeles California
  2. Yannick Michel
    Yannick Michel France SotM Winner Subscriber
    France
  3. Yannick Michel
    France
    @Remus1956 Hello. I’ve just received the burner. I’m not satisfied with it. The tank becomes very hot after just a few minutes. The flame is smaller than with the original lipstick. Did you experiment this with yours ??
  4. Remus1956
    @Yannick Michel nope...I didn't have your situation at all. Mine runs just like the original. Just looks a little different.
    Try picking it to make sure it's clear. Might have something in the jet
  5. Yannick Michel
    France
    @Remus1956 my original pricker is too large for using it with this burner. The selle told me that the size of the jet was around 0,2mm. After 5 minutes the tank becomes very hot.
  6. Remus1956
    @Yannick Michel Dont know what to tell you, sounds like you got a weird bad one. I would return it and get another original one.
    The one I got was from a different source than yours, maybe its made by someone else. Mine works just fine, just didnt have mesh and looked different.
  7. Yannick Michel
    France
    FF38666C-71BC-4E91-AC82-D2F888C52870.jpeg @Remus1956 after 4 minutes I can not touch the tank if I want to pump more… very strange.
    Here is a photo of the flame.
  8. Remus1956
    Interesting. @Yannick Michel It looks good from a burning prospective, but running hot is interesting. Is this in a fireplace? Have you tried burning it outside? Looks tight in there, may be getting reflective heat.
  9. Yannick Michel
    France
    @Remus1956 I don’t have this hot tank when I use the original lipstick in the same place. I think I will not keep it. This korean lipstick is in full brass I think. There is may be something to do with the material used to make the lipstick. But yours doesn’t have this problem…
  10. Blackdog
    Dreaming of snow
    The jet orifice in the 'lipstick' vaporisers should be 0.23mm, smaller than the 0.32mm nipples fitted to most other stoves. Some original lipstck vaporisers were all brass, some were a combination of steel and brass.
  11. Yannick Michel
    France
    @Blackdog Thank you. This one appears to have a smaller diameter than the original because I can not use my Primus 96 original pricker.
  12. Tony Press
    @Yannick Michel
    If your jet is only 0.20mm you could carefully enlarge it with a hand micro drill. I have some tapered ones that I use for cleaning small orifices.
    Can you post a photo of your new “lipstick”?
  13. Yannick Michel
    France
    8406BEBF-652D-4FF5-973B-ED56445DC570.jpeg @Tony Press Here it is. I will not keep it. My other concern is that the tank becomes very hot just after a few minutes.
  14. Tony Press
    Ok.
    Are Swedish No. 96 lipsticks out of stock everywhere now?
  15. snwcmpr
    @Yannick Michel
    Please post a photo of the side view of your stove without the windscreen.
    I wish to see this better.
  16. Yannick Michel
    France
  17. snwcmpr
    That doesn't look right to me. But, I will let 'my betters' comment.
  18. Remus1956
    That's not how mine looks either
  19. Yannick Michel
    France
  20. Blackdog
    Dreaming of snow
