general question
Discussion in 'Stove Forum' started by st3v3, Jan 13, 2008.
  1. Ian
    Ian Subscriber
    West Yorkshire
    But isn't this procedure just priming or preheating by a different name? You can't run the stove on the air-rich mixture continuously as you would be having to pump it almost continuously, so you switch to fuel-only once the burner is hot enough to vapourise the fuel, ie. primed. :?
  2. bajabum
    bajabum R.I.P.
    You were expecting Truth in advertising ?????
    :p
  3. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    Well, yeah, priming is just heating up part of the burner to the point that its heat will vaporize the fuel. What the SnowPeak does is make the priming flame look like a cooking flame. Is this a marketing gimmick? I suppose it can be considered an attempt to make a liquid fueled stove more acceptable to gazzers.
    On the other hand, it's less prone to flaring than other liquid fuel stoves, and would be safer to start indoors (something I'd still try to avoid). Also, you can start cooking on the priming flame, which is pretty much a waste of time with most liquid fuel stoves.
    ....Arch
  4. barrabruce
    barrabruce Subscriber
    FNQ HorseTrail-Lier
    Nice point Arch
