Heinze Geniol Dutch Army
Discussion in 'Petromax & Aida' started by Dutch_Peter, Aug 22, 2014.
  1. Odd
    Östhammar, Sweden
    Yes, You can
    - but why on earth would you want to go to a much more unsafe fuel compared to kerosene!?!
    In the German (Dutch) Army stove you don't need to use alcohol for preheating due to the built-in rapid pre-heater so no need to have alcohol handy. And, as you probably know, alcohol and gasoline can both burn above a puddle of spilled fuel (or worse - inside a fuel container!) which kerosene cannot do. It needs a wick or a pressurised spray to burn.
    And the colder it is the easier alcohol and gasoline will ignite above the puddle...
  2. Tony Press
    @woodyoumind
    The Heinze Geniol should not be run on gasoline (Coleman fuel/white gas etc). It might fire up and look good - but it is inherently unsafe.
    It is designed to run on kerosene and good quality diesel. I run my two on kero. The biggest dirty fuel clean-up job I’ve done has been a Heinze Geniol that was clogged with diesel...
  3. snwcmpr
    I would not recommend it. It runs so well on kerosene.
    And with the price of CF in Canada why would you want to?
  4. woodyoumind
    canada
    Good mourning Masters
    I swear I will use Kerosene in my corn flackes
    But dont shoot me
    regards
