Help to identify and how to light?
Discussion in 'Stove Forum' started by Clogger, Oct 5, 2024.
  1. Clogger Australia
    Australia
    I’ve taken the red knob screw out. Is there anything missing?
    Does it just need to be more tightly bolted on?
  2. Firestarter United Kingdom
    Plymstock Devon United Kingdom
    It's a bit late here for a long answer, I don't know what should be inside as it's an unknown stove , I think there is the remnant of the seal at the bottom of the nut sometimes there is a washer you can try tightening the nut or as suggested earlier get some graphite tape to make a new one. It's also known as a stuffing box and possibly used graphite string as the seal, You can use the search function (the magnifying glass in the top right hand corner) to research this. Also read the threads I linked to
    Regards Dave.
  3. Clogger Australia
    Australia
    Thanks Firestarter.
  4. Clogger Australia
    Australia
    This is what I found inside the nut. I presume I need graphite packing to replace the seal? IMG_5357.jpeg
  5. Tony Press
    Yes, you’ll need some graphite. That might be asbestos you have there, so don’t snort it.
    If you send me a message (use “Conversations”) I’ll send you some graphite tape you can cut and roll for packing.
  6. Firestarter United Kingdom
    I was going to suggest that Tony might know where to find some graphite in Australia and +1 on the warning about asbestos, I am always very cautious when I find any fibrous material on stoves and usually wet it to avoid creating dust or loose fibres.
    Dave.
  7. Clogger Australia
    Australia
    Thanks for the offer Tony P. I ordered some graphite online after a search. Thanks about the warning re asbestos!
  8. snwcmpr
    Curious what you ordered.
  9. Clogger Australia
    Australia
  10. snwcmpr
    Can you please provide more details?
  11. fjfj765
    fjfj765 United States Subscriber
    California
    I recommend the OCP graphite ribbon.
  12. ROBBO55
    G'day @Clogger and welcome to CCS.
    An interesting stove you have there.
    Is that a crack in the small tube at the top, between the fuel vaporization chamber and the valve?
  13. Clogger Australia
    Australia
    It appears to be a soldered repair that hasn’t been polished smoothed.
  14. Clogger Australia
    Australia
  15. snwcmpr
    Thank you.
  16. ROBBO55
    That's OK then and shouldn't be a problem.
  17. Clogger Australia
    Australia
  18. Firestarter United Kingdom
    Well done, that's looking a lot better if a little rich, it may improve more with a pot or kettle on it.
    Dave.
  19. snwcmpr
    Nice picture
  20. Clogger Australia
    Australia
    Thats a challenge then!
