Hiker+ stuck valve
Discussion in 'Fettling Forum' started by Dwight, Aug 20, 2024.
  1. Dwight
    Crescent City, California
  2. hikerduane
    Plumas County, CA
    Valve or pump or both? You don’t make sense. Leary of the link.
  3. Dwight
    Air is compressed when I press the pump, but none goes into the tank. The video shows the pump coming back out after each press.
  4. theyellowdog
    Take out the plunger, pour some kerosene (fuel) in the pump tube. Put plunger back. Push the kerosene through with the pump.
  5. Dwight
    It worked. Thank you!
  6. theyellowdog
    Glad it worked. Fuel is less compressible than air, so it forces the non return valve open.
