GREAT--!!! Sell that to Disney and buy all the lamps and stoves you want!!!! sort of like "the brave little toaster"--
strange .......this is just what my good doctor was saying .. im self medicating again .....& this weekends prescription is a weekend permaculture party in wales . i tell the vegetarians ..my home brew stout has gelatine in it ....helps stop the spills when youve over imbibed ,,,,,,that quietens demands of ..lets have a go on your home brew ,mate. the 111s & coffee percs are out ...ive been nominated as purveyor of coffee to the gig. my language gets colourful when some off their face idiot comes around wakening me up in the small hours.......thats any time between 02.00 & 09.00... wanting ...a cup of coffee, mate.... when tired & dealing with scabheads , i can flare faster than a 111 with no preheat keep it in the blue perkynick........ with burnt pinkies .....the gauntlet that mr spuds suggested i threw , i should really have used during soldering .
this comment , in my present state , is any thing but helpful..... your place will be my first port of call when theyre baying at my heels. dave gibsons advises... to buy disney & sell all the stoves & lamps that i dont want ... well this just leaves me even more confused ... im glad im reading this in my own language. nick
Hi Nick Your photos show that your blowlamps actually move as a herd ( you have all heard of the collective, 'a herd of blowlamps'). They obviously surround non-blowlamp brass items and destroy them. Send the photos to the BBC - they could be the next protagonists in Doctor Who. (Yes, and as David has said - keep taking the medication!)
Are you sure those b*****s aren't breeding? I have a max Sievert petrol blowlamp on a shelf in the bedroom and a Primus paraffin one somewhere in the garage. No way am I leaving the two alone together..... I used the Sievert to fix my Optimus 00.
Nick, Where is the blow lamp equivalent of '7 of 9' ... gotta be a cutie They are just like the Borg Collective ... not to be confused with the Borg Collection (naff knickers for blokes from the 80's designed by a tennis playing Swede , who'da thunk !) nor The Bourne(ville) Connection (I believe it was a book & film about bars or chocolate (don't think our foreign brothers will get that)), evil little feckers ! Sorry about the mitts .. Can I send you me n.1 Phoebus for a little soldering around the riser tube Could the collective noun be a 'scorch of blow lamps' ? Enjoy the Flame Spudz
Spudz Stop being a big wuss ! Pot a dowel in the riser tube, invert the tank, apply heat evenly and realign the riser with the dowel if need be. They have flanges on them, so it shouldn't drop out. The solder should run to the lowest point and there's a good chance the leak will be sealed and the riser firmed up. What can you lose ? Can't be worse than what you have now If you don't have a go why did you buy the very nice blowie the other day ? Otherwise send it to Nick !
Who are you calling a wuss ? Did you spill my pint ? Ah, but you see I can't, 'cause the burner is stuck hard on the riser. It was when I tried to unscrew the burner, that I noticed the 'play' in the riser at the tank joint! Did you spill my pint ? it has a nice flame ? Did you spill my pint ? Right then, time to buy some thin gauge solder and some flux ... now where's that blowtorch ? Spudz ... feeling better already ... Who spilled my pint ?????
Even better you can straighten things up when holding the burner head - with a thick glove. Try it without any more solder etc., just re-melt what is already there, might work if it's upside down. Nothing to lose. . . . . . . but don't do it after drinking . . . . . mind you, you can't as some bugger spilt your pint Cheers ( oops . . . sorry ! )
Right then !! I'm psyched up for this !! I've read that you should put some water in the tank when soldering, but if I do that and turn the stove upside down, will the water not sit near where I'm trying to melt the solder and act as a heat sink ? To water or not to water ? Spudz
Flush it out a few times, then leave to dry in hot Italian sun 8) Should be safe as long as it's only been used for paraffin and nothing more volatile Go for it
Water ? Why put water? In that case you will not be able to increase heat above 100 centi degree which is unadequate to melt solder. Right? Best regards, Sefa
#-o The bleedin' obvious goes sailing past my eyes, and I don't see it, yet again ! #-o #-o Looks like I have some more studying to do before I attempt my 1st year CCS exams Spudz
The thinking is that the parts of the stove below the level of the water, in this case; legs & pump wil not increase in temp above 100?C and thus will not fall off, whilst that above the water level ie. top of riser tube can increase above 100?C so that solder will melt. I t worked for me when I did a similar repair on a Pri. No. 1. You don't fill the tank completely #-o
