Keeping BIC lighter with Svea stove
Discussion in 'Stove Forum' started by Mustang67ford, Jul 9, 2018.
  1. ally
    ally Subscriber
    Lincoln, UK
    I just purchased a kydex neck sheath for a bic, my neighbours keep nicking mine (!)
    pop "Necklace Door-lighter in Kydex BIC range most d'ETFr" into ebay
  2. Ed Winskill
    I use the cheaper "bic-type" lighters rather than Bics; they are easier to light when your fingers are numb, and easier for kids to light.
  3. Marc
    Marc Subscriber
    Oregon, USA
    Bic is the only lighter I've found the be reliable.
    You can pop the child safety ring covering the striker wheel off to make it easier to strike. I generally don't bother, but this took about 15 seconds to do, most of that was fumbling my multitool out of my pocket:
  4. snwcmpr
    Bic lighters work great .... except when they do not.
  5. Ed Winskill
    A few years back out one of our winter campouts, I ran a couple of my grandkids through some winter fire-building exercises, etc. They were early teenagers, say 13. The boy had some trouble with a Bic; the girl couldn't light it. They both did fine with the cheaper, flat knockoffs.
  6. snwcmpr
  7. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    Probably not, but if you use a rubber band to hold down the fuel flow button and then drop the lighter into a bottle of water, it will swim around amusingly.
    ....Arch
  8. geeves
    geeves New Zealand Subscriber
    Christchurch NZ
    The mini bic fits inside no issue. I used to keep lighters in many places as well but had an audit in the name of weight and only had one left. First trip it did the flying spring thing. This left 4 of us with 2 stoves 5 candles and 2 matches for the weekend. Im carrying 5 lighters again.
  9. Simes
    Simes R.I.P.
    Oooops.
  10. Simes
    Simes R.I.P.
    Oooops.
  11. Marc
    Marc Subscriber
    Oregon, USA
    What knockoff brand? I've not found anything but Bic to be reliable, always open to less expensive / more common alternatives.
  12. snwcmpr
    I think he means the common flat lighters about the same size as a standard Bic.
  13. Marc
    Marc Subscriber
    Oregon, USA
    I think so too, but I've never found one reliable and had written them off en-mass. If he has a specific brand in mind, I'd give it a shot. Probably all made in the same China factory.
  14. bbsteinle
    bbsteinle United States Subscriber
    Spokane, WA USA
    Scripto.
    Basil
  15. Ed Winskill
    None are particularly reliable, so I have many. Those knockoffs are easier to light, which I proved to my satisfaction with the grandchild winter test. That's all. I have on occasion found Bics to be hard to light, myself.
  16. snwcmpr
    Me, too.
  17. Marc
    Marc Subscriber
    Oregon, USA
    Aye cap'n. Thank you sir.
  18. Robert Bruce SotM Winner
    Springrange NSW Australia
    When too cold they wil not light. So I put one in my pocket, that way they keep a bit warm , then they work. The pocket thing only draw back is they sometime get a bit of fluf in the mechanism which is a bit hard to get out especially if your fingers are freezing. They are “butain” not “propane” so cold is more of a problem.
    Rob
  19. geeves
    Christchurch NZ
    Also found the electronic types less reliable except in one circumstance. Ever tried to light a flint and rolling wheel type with wet hands. Once that wheel is wet forget it
  20. snwcmpr
    Simply light it with another lighter ........... assuming you have one.
