Kerosene Pressure Stoves Sizes
Discussion in 'Stove Forum' started by jmdgatt, May 24, 2019.
  1. jmdgatt
    jmdgatt Subscriber
    Malta
    I am interested to know the the manner by which the kerosene pressure stoves were classified as regards their size.
    Were the stoves sized according to the burner size or according to tank size? Is there any relation between the two?
    I appreciate if someone forwards some kind of table or other guide.
    Thanks.
  2. kerophile
    No standardisation of numbering of stoves either by an individual maker or between competing manufacturers.
    Have a look at this listing from Base Camp:
    Paraffin stove reference numbers
  3. jmdgatt
    jmdgatt Subscriber
    Malta
    Thanks kerophile. Very interesting information.
    If I may pose another question. What sizes of roarer burners (height and thread diameter) were installed on these pressure stoves (I am after the 'normal' ones, not the foldable camping stoves)
    Thanks.
    Joseph
  4. cmb56 Sweden
    Norrköping, Sweden
    @jmdgatt
    Can I suggest you to be a subscriber?
    If so, you can find all of this information in the Reference Library that is only accessable to subscribers.
    In my opinion, well worth money.
    Michael
  5. kerophile
  6. jmdgatt
    jmdgatt Subscriber
    Malta
    @cmb56
    Thanks for your suggestion. I am now a subscriber.
    @kerophile
    Thanks for the link. Great and detailed information.
    I am restoring an old pressure stove. It was equipped with a 203/213 burner. Sadly the burner has deep dents on its pipework (probably damaged by a spanner when it was installed/replaced). I would like to replace the burner. Is this burner available sommwhere?
    Thanks.
    Joseph
  7. kerophile
    Hi the Op.203/213 burner is a BIG burner. It is typically specified for a No.3 stove:
    Primus No.3 - 1960s
    Are you sure that this is the one you seek?
  8. kerophile
    Check the diameter of this large burner against the riser tube of your stove.
  9. kerophile
  10. JP2
    JP2 Subscriber
    Canada
    @jmdg
    Welcome on board
  11. Jeremy Belgrave-Lock
    Jeremy Belgrave-Lock United Kingdom Subscriber
    Norfolk England
    @jmdgatt
    A picture paints a thousand words, besides we are a nosy bunch.
    Regards Jeremy
  12. jmdgatt
    jmdgatt Subscriber
    Malta
    These are my stove and its burner. Sorry but I have not started cleaning yet.
  13. Tony Press
    @jmdgatt
    If you can push a 3 or 4mm steel wire up past that crease in the burner, your burner may ok.
    I would give it a good clean with carburettor cleaner, make sure the nipple and jet is clean, then test it for leaks.
  14. kerophile
