msr burner pump leaking fuel
Diskussion i 'Stove Forum' startad av Benjamin Mandel, 8 november 2023.
  1. Benjamin Mandel
    18 mars 2022
    5
    Från:
    No
    Hello Everybody!
    I have the msr international burner for 3 years. In the last trip I suddenly realized it started leaking fuel through the control valve on the pump.. I opened the valve, checked the O-Ring, it looks ok for me .. anyways, will be happy to hear your options.
    And another question:
    I actually don't have any spear o-rings now, somebody can refer me to a standard of these o-rings? I mean can I get a replacement from some other sources, other then Msrs?
    Best!
  2. snwcmpr
    16 november 2011
    21.929
    Från:
    I always spit on the fuel line going into that opening. Never had a failure ..... yet.
  3. 907_Nick
    907_Nick United States Subscriber
    9 juni 2020
    84
    Från:
    Alaska
    Just to make sure, this is the o-ring you're talking about right?
    The size depends on your specific pump, mine takes the red -007 size. I go with viton for the material when I buy mine, cold weather since I live in Alaska.
    Description Use Size (AS568A#)
    Red (small) Control Valve (B Pump) -007
    Black (small) Control Valve (A Pump) -008
    There is an ebay seller who sells o-ring kits at a reasonable price. I've never checked to see if he has the correct sizes/materials, but the reviews would seem to indicate so.
  4. Benjamin Mandel
    18 mars 2022
    5
    Från:
    No
    Yes, sir. Exactly this one.
    I will try to find it!!
    Thanks a lot!!
  5. snwcmpr
    16 november 2011
    21.929
    Från:
    Sorry I read that wrong.
    My post is still valid, but does not apply here. ](*,)
  6. 907_Nick
    9 juni 2020
    84
    Från:
    Alaska
    You can also buy them from Mcmaster Carr or Grainger online. Buna-N would work for material too and is easier to find down to -40degF compliant.
  7. rocketboy
    13 november 2011
    20
    Från:
    Alabama, USA
    Anyone know what size the green Dragonfly fuel line o-rings are? I can't seem to figure it out. Metric maybe?
  8. 907_Nick
    9 juni 2020
    84
    Från:
    Alaska
    I have a maintenance kit for my Dragonfly, I'll try and measure them tonight.
  9. 907_Nick
    9 juni 2020
    84
    Från:
    Alaska
    That green o-ring for the Dragonfly measures closest to a metric 1.78x6.75, but isn't exactly those specs. That said, I'd feel pretty confident that a 1.78x6.75 would work.
  10. rocketboy
    13 november 2011
    20
    Från:
    Alabama, USA
