MSR RapidFire O-Ring
Discussion in 'Fettling Forum' started by swt2c, Nov 25, 2015.
  1. Naomi United States
    PA
    MSR sent me a spec, it said Nitrile Buna. The o-ring fits and does not leak.
    OakNJ PM me your address.
  2. OakNJ United States
    Northern NJ
  3. snwcmpr
  4. hikerduane
    Plumas County, CA
    I've used the Oring Store for my MSR pumps.
  5. Naomi United States
    PA
    The snippet from MSR said that the Control Valve o-ring size is -008. and nitrile. That's all the info they could find.
    I didn't realise that the Actuator Valve o-ring would be a different size. Until I found the manual I didn't realise that there were 2 o-rings. In the diagram in the manual it looks like the Actuator Valve o-ring is larger. I measured the original before ordering the things from NelsonAudio and picked the closest size. It seems to fit.
  6. James E Fielden United States
    Knoxville, TN USA
    Hello, is that for where it connects to the canister? I have the link for the ones in UK, but 15 pounds shipping is a bit much. Do you have any extras?
  7. OakNJ United States
    Northern NJ
    My RapidFire works just fine. It will also work with some of the Lindal to 1 lb. propane adapters but not all and I am a little leary about using on a regular basis. I am not crazy about it and would worry about low temperatures and proper sealing, etc. with the old style Iso-butane connection this stove has. I have the newer Windpro II which is awesome and works well with smaller pots than the RapidFire. Just as the RapidFire is a Whisperlite clone, the Windpro/Windpro II is a Simmerlite clone.
    I have a question... Is there ANY way to correctly change the metal hose and connection on the RapidFire or even the Dragonfly and attach a modern Lindal style connection. Also, does anybody have a source for replacement O'rings on the modern Lindal style valve for just about any stove?
  8. OakNJ United States
    Northern NJ
    I actually have had no trouble with the RapidFire whatsoever. Great Stove!
