My 502 project....
Discussion in 'Stove Forum' started by skalkaho, Oct 10, 2014.
  1. skalkaho
    I don't have a 500, so I can't compare. But you need a 400 and 502!
  2. kerry460
    kerry460 Australia R.I.P.
    one day . it will happen .
    thanks for the info .
    and once again , top job mate , it looks bloody good :thumbup: :thumbup:
    cheers,
    kerry
  3. Murph
    Milwaukee WI, USA
    Glad the decals worked well for you!
    I had the same decals, but the adhesive didn't work the way I wanted it to for my 502, so I went with a water slide transfer, much better for my needs!
    https://classiccampstoves.com/threads/25734
    Murph
  4. mr optimus
    Brilliant work and transformation Lonnie
  5. Doc Mark
    Morning, All,
    I would rate the simmer on a good 500 to be just about the best, but the 400 comes awfully close to being the same, in a good stove. The 502, whilst not quite as good as the former pair, also offers a very, very good simmer, that is predictable, and very dependable. All three stoves are flat-out fantastic when it comes to actual cooking, plus the 400 is a screamer when it comes to power, too!! The 500 and 502, whilst a bit less powerful on the top end, have MORE than enough power to get your jobs done, and done well!! With this trio of Coleman single-burner stoves, you're in for some top of the line stove fun, Mates!! Doesn't get too much better than that! Take care, and God Bless!
  6. kerry460
    thanks Doc . interesting info .
    cheers,
    kerry
  7. OMC
    OMC United States Subscriber
    Geez Doc I'm feelin like Mr counterpoint, i hate that. Your experience is off the charts good with input that continues to be very much appreciated. Thank you for all you do.
    I'm a newbie, I'm learnin and "gotta a lot of nerve", I don't even have a 500 but
    re "the simmer on a good 500 to be just about the best".
    ASIDE from that i think i concur w/all info posted.
    That surprises me, would you have a "windscreen caveat" w/that 500 simmer?(w/what type windscreen?, as 500's orig windscreens are rare).
    The 500 burner is farthest from the pot and of the 3 benefits the most from a windscreen, even in no wind, to get consistent low heat to the pot. Some may say it NEEDS a windscreen.
    Simmer is not easy to compare? Would not low consistent heat AND more evenly distributed be factors.
    All 3 w/o windscreen, i would think would comes down to the 400 & 502, just me. 400 having an improved burner. Both 400 & 502 have improved burners vs the 500. "My "guess" is w/o windscreens they both may simmer better than a 500 w/windscreen, others disagree.
    Cooking some rice on a cool windy day may help me see how the 502 does vs 400.
    If 3 HAVE a windsceeen I think 400 will improve the most but, for simmer it may not be a noticeable difference.
    I'm not a know-all and this isn't the end-all. I often miss things along the way. It's just w/500's burner much farther from the pot, totally exposed...
    respectfully at least curious about rating it a "just about the best simmer", omc
    PS that said, the, as Gerry says, "reliable as an anvil" 502 is plenty good, like 400 in-all wind/weather so I like the 502. Personally i think I can say I will ALWAYS be happy to use it(winter camping, i may never do again, if i did in sub-zero, it be a 400 4 me).
    Camping in 10 below confession: Being an ill prepared young dumb numb nuts, my pot of water began to ice-over atop a stove... today, at 10 below I wouldn't take a 500 or 502.
