Need help with ID of stove
Discussion in 'Stove Forum' started by Whippet, Jan 10, 2005.
  1. Whippet
    Need help on the model. I know it is a Primus with some Arabic writing. Serial number(on the neck) puts it in the mid-60s. Won't hold pressure(leather seal is tore. Just learning how to work it. Need to know where to get a new seal, and any help with correct way to run it.I will try to post a pic, but don't know if I can.
  2. Whippet
    I know it liioks like a primus #1. If that helps. Cant figure out how to post the pic
  3. CWilkins
    CWilkins Subscriber
    Hi,
    Lets start with the leather. Are you referring to the leather on the pump? If so I can give you a member here who makes them to order. (very reasonable).
    To post a pic you need a place for it to be stored. Either a website or photbucket, webshots etc. Then link it to your post with the Img button.
    Press the button once and (|imgRemoved|) will appear
    Chuck
