Nice Tools
Discussion in 'Fettling Forum' started by RonPH, Dec 30, 2011.
  1. RonPH
    Since Harbor Freight was doing a sale, I decided to drop by and pick up a few things.
    Mini sandblaster/etching tool. Now, those stubborn black gunk in the burner crevices will come off and shine. As well as get more detail on letterings.
    Torx mini star wrench
    Of course it would not be complete if I did not get a 2lb. 220 grit aluminum oxide.
    I wanted to get this
    A hydraulic crimp tool which had different sizes so I could do a professional finish on most adaptors but stopped short of getting it at this time. It will always be there at HF so when I truly need it, I know where to get one.
    Interestingly there are a lot of tools I drool but no space to store :doh:
    Sale ends Dec 31.
    Ron
  2. litetrek
    Cool. Those are nice tools. I especially like the "blaster" ... I need one of those. HF is a good resource. I discovered recently that the crimping tool for coaxial cable is just about the right size to crimp a sleeve onto a fuel line. If you already have one you're in luck. You can take an RG6 cable female end fitting and cut the nut plus center sleeve off of it. What you are left with is a nice ferrel. When I did it the ferrel was just a little loose after crimping so I wrapped it in several layers of aluminum tape to act as a shim and then crimped it again. It worked!
  3. mr optimus
    Hi Ron brilliant little selection of tools for stove restoration the mini sand blaster will come in very handy i wonder if it will work well for derusting any parts of a stove that is steel.
    At a quick glimpse i thought it was a air brush they all so are use full any stoves or lanterns that need paint work they are ideal and they give a great finish and in most cases it works out cheaper well done there Ron
  4. hikerduane
    Plumas County, CA
    I need a Torx like you show, so many sizes, I don't want to buy 6 to get the size I need. Thanks Ron.
  5. RonPH
    Hi Brian, the small blaster is just so you can just blast the rust spots on the stove tin, hardened gunk on the burner or crevices, glass etching - for under $25 plus another $9 for 2lb aluminum oxide 220 grit.
    Hey Duane, really now, the piece I bought costs $5.50, betcha the one piece you need would cost more buddy.
    Ron
  6. mr optimus
    Hi Ron For under $25.00 thats a bargain i expected you to pay more for such a good piece of kit, even the oxide grit could be re used if collected
  7. RonPH
    Hey Brian, I opted for detailing, but there was one sold for only $15 and $20 see pics, but its for larger capacity or wider swath blasting. You can check it out HERE for the $15 item or HERE for the $20 item
    Brian, you said "good piece of kit" well, it remains to be seen since its all "made in China/Taiwan"
    Ron
    Photos from Harbor Freight website
  8. yonadav
    yonadav Subscriber
    Israel
    Hey Ron,
    Thanks for showing the mini sandblaster - I never knew it existing. You bet I'm going to buy one.
    My solution for the star wrench is this set of all kinds of "unusual" tips:
    Yonadav
  9. RonPH
    Hey Yonadav, nice set of bits :thumbup: They always come in handy alright for those odd screw heads.
    Ughhhhh! I need to organize again my stuff :doh:
    Ron
  10. RonPH
    I set up the blaster and tried it on a penny that had some black substance on it. Attached 3 pictures
    Before sandblasting
    After sandblasting
    Washed and cleaned with 1000 ss wool
    Notice that the detail of Abe is nice and sharp. I would say the "eraser" does get the job done :thumbup: The lower portion of the coin that has not been sandblasted is where the lip of the locking pliers gripped the coin.
    Ron
  11. toonsgt
    200 aluminum oxide it pretty aggressive IMHO. Try walnut shells. They leave a much more polished surface if that "gun" will handle them.
    Mike
  12. RonPH
    Mike, it will only take 220 grit so if there are walnut shells that's 220 grit the I will give it a go. I wonder if the shells have residual oils that give it the shine.
    Ron
  13. toonsgt
    It's not the oils. It's simply that walnut shells are harder than paint, but won't abrade metal surfaces and only take off the gunk. Aluminum oxide is harder than any metal I'm aware of, so I wouldn't use it on any polished surfaces. You'll spend more effort getting the shine back than you save blasting away gunk. Now, for rust and metal that you're gonna paint, you'll be very happy with the results.
    Mike
  14. RonPH
    Interesting :thumbup: Thanks Mike. Happy New Year
    Ron
