I have a newly acquired 199 that I recently purchased. When I received it, it did not work. Having rebuilt a 111T I tore it apart, cleaned it and then reassembled it. After a quick warm up it, develops a nice blue flame and appears to be burning as it should when compared to the 111T. However it makes a buzzing sound which is outside my small realm of experience. I am using kerosene and currently the cleaning needle is not installed. Any ideas as to the cause of the of the buzzing?
Hi, try putting the burner caps from your 111t on it. It that works you will know where the problem is. The noise is probably the flame burning under or between the caps. Causes:- Too little pressure Mismatching caps Inner cap missing Carbon on caps Lighting when spirit cup still burning. You have a great stove, don't give up.
Yes, easily - I've you've cr&p in the fuel tank it only takes around 10 nanoseconds for a piece of that to block a jet. But it sounds like underburn to me, too - as per the previous post...
111T burners will work on all three fuels. If it was purchased here in the US, I'd wager it's set up for CF. With no integral pump. You'd have to pressurize the fount with a external mini pump to burn kero, I would think. Murph
