NRV removal tips?
Discussion in 'Stove Forum' started by Metropolitantrout, Oct 29, 2014.
  1. Christer Carlsson
    Hi Daniel.
    Well, most steels would suffice in my opinion.
    If it's not meant as a proffessional tool to be in daily use, and last for ever, any steel should outrank the softer brass in the NRV.
    I have used steel with a carbon ratio that allows it to be hardened, but as I think I said somewhere; it's actually overkill.
    You could try a suitable screw that's large enough to fit the pump tube if it's mainly a question of getting hold of things you already have lying about.
  2. annfield
    annfield Subscriber
    Thanks for your reply.
    With the risk of sounding like an idiot but I do not understand how the prototype tool head have been fastened to the threaded rod in the picture above.
    I mean if a threaded a M8 hole is drilled into the prototype tool head and the threaded rod is inserted clockwise.
    Will engaging the NRV counter-clockwise not result in the tool head getting unwinded?
    Is the nut next to the tool head the answer to this mystery or perhaps the hole is drilled with a left-handed thread?
  3. Christer Carlsson
    Yes, that nut is the answer. It locks the head, and should of course be tightened very hard.
    It could also be a good idea to lock things even further with the strongest Loctite, or any other chemical threadlock.
    Or why not weld it together?
    Mind you, this was only a test tool to see how the idea would work. But it did actually work well enough despite its flimsy look, so as a makeshift tool, it's quite allright.
  4. annfield
    annfield Subscriber
    Thank you for explaining the concept of a counter/jam nut. I have not heard of it before.
