NRV repair.
Discussion in 'Fettling Forum' started by kerophile, Mar 4, 2011.
  1. ROBBO55
    @Julian Hopkins , this might get his attention @loco7stove otherwise you can try sending him a private message by clicking on him and select "start a conversation "
  2. Radler
  3. james charles bennett United Kingdom
    Leicester
    hi where can i get a nrv removal tool like the one in your post?
  4. hikerduane
    Plumas County, CA
    Stu who made the tool in the early post, does not follow the forum much if at all anymore.
    There are a few topics where members have made a simple one, maybe they will check in with a link.
  5. james charles bennett United Kingdom
    Leicester
    well im up the creek without a paddle lol.
    may as well make one myself thanks for replying mate and take care
    Regards to you
  6. snwcmpr
    Stu was here a few days ago, looking.
  7. igh371
    Durham
    @james charles bennett there are some good quality NRV tools occasionally available on Ebay.com from specialist sellers in South Korea, Japan & Taiwan (eg simonchantwus). Search for 'lamp stove check valve wrench', do not expect to be cheap. But beware Chinese copies which in many cases do not cater for Primus type NRVs.
    Also beware that even the best tools cannot be guaranteed to shift the worst case stuck NRVs, especially if the heads are already damaged from previous failed extraction attempts. To give the best chance always soak with penetrating fluid first, and then fill tank with boiling water immediately before using the tool. @kerophile's original post at the beginning of this thread gives the main advice you need. Sometimes however radical surgery, extracting the whole pump from the stove, has to be resorted to as a last resort. Good luck:thumbup:
  8. james charles bennett United Kingdom
    Leicester
