Optimus 22B fuel
Discussion in 'Stove Forum' started by Dwight, Jul 11, 2024.
  1. Dwight
    Crescent City, California
    I understand that these were made for various fuels. How do you know what fuel to use in this stove? IMG_1155.jpeg IMG_1154.jpeg
  2. hikerduane
    Plumas County, CA
    Case would be embossed “22B”, plus burners for gas/petrol/white gas only had two tubes, kero have four, then alcohol have a different design. Kero version could also burn gas, working better with kero jets removed and gas or multi fuel jets installed.
  3. ajvuik
    ajvuik Subscriber
    Netherlands
    The burner that you show is a petrol/gas burner. You can easily identify them, as they have no fuel running through the top of the head. You can clearly see that one tube is open, for running alcohol down to the cup, and the other is closed off and only acts as a heat pipe.
    A kero burner has 3 or 4 tubes which do carry fuel through the top plate to vaporize the fuel and lead the heated vapor to the jet.
    So, as far as I can see, this is a 22b
    Arjan
