Optimus 8R Leaking?
Discussion in 'Fettling Forum' started by D21400, Dec 3, 2017.
  1. D21400
    Antwerp, Belgium
    Hi,
    I recently noticed after like 8 min on full blast cooking my R8 leaks.
    Is there a way to solve this?
    Thanks!
    Dries
  2. kerophile
    Hi @D21400 You should be able to stop this leak by slightly tightening the packing nut (the hexagonal nut which the regulator shaft passes through). This will cause the graphite packing to compress around the regulator spindle and hopefully stop any fuel leak.
    If you tighten too much the spindle becomes too stiff to turn, and you will need to slacken-off slightly.
  3. D21400
    Antwerp, Belgium
    The Nut was indeed loose. Thanks!
  4. BillyBear
    I love those little 8r's! I just overhauled one and gave it to my neice. She is all about liquid fuel equipment now, lol....it's fun to see. Enjoy the stove!
