Optimus 8R, offset burner
Discussion in 'Stove Forum' started by LukeMcE, May 8, 2010.
  1. LukeMcE
    Just bought on 8R of Ebay, looks like an unreal stove, came with the mini pump as well. I wasn't that keen to buy international off ebay but wanted an 8R and that seemed like the only place to get one. Pretty happy though, only took a week to get from the USA to Ausrtalia, i've had stuff take longer from local ebay sales.
    Only thing is that the burner is not centered in the middle of the pot supports. Is this normal? I don't think it will be an issue but just thought i'd check. Cheers
  2. Henry
    Where's the pics then :roll:
    The feed pipe from the tank to the burner may be a little bent, have you tried tweeking it?
  3. LukeMcE
    Now with pics. Cheers
    Luke
  4. Henry
    Looking from the side it's leaning back towards the lid hinge, Just needs the feed tube tweeking a bit.
  5. itchy
    Looks to me that the hinged front has not dropped down completely. If it were flat the burner would be a bit more forward.
  6. RonPH
    Yes, I definitely agree, the hinge should go down flat against a level surface that's why the burner is off center. May be something obstructing it.
    Ron
  7. Mendologist
    Hambleton, Selby, North Yorkshire
    Be careful if you tweak the fuel tube - it may fracture if bent.
    Try spannering it further into the tank a turn or two.
    I have two 8R's. Both have slightly differing positions.
    No probs with either.
  8. geeves
    geeves New Zealand Subscriber
    Christchurch NZ
    It looks new. Has it ever been lit?
  9. LukeMcE
    Thanks fellas for the feedback. The fuel tube is not bent and i don't think i will be able to screw the burner in any further into the tank. i was thinking that i might put something under the burner to both raise the burner and protect the case. What do you guys think.
    Geeves, it had been lit before i got it but not many times i think. Works great with the mini pump. Cheers
    Luke
  10. geeves
    Christchurch NZ
    I wish the one I just bought had looked that good but it goes fine so that good enough for me
  11. LukeMcE
    Yeah, it does look good but it cost more than i had hoped. I had missed out on a few 8R's and this one was in real good condition and came with a mini pump so i thought it was worth a bit more.
