Optimus 99 Heat Shield Repair
Discussion in 'Fettling Forum' started by roby03, Dec 12, 2015.
  1. roby03
    DSCF0899.JPG DSCF0893.JPG The windscreen on this stove, the part that covers the tank, was beyond repair.
    I decided to make a new part. I first cut all but 1/2 inch off of the damaged
    part. I used a curved pair of tin snips, then straighten the edges with a
    hammer and a small block of wood, filed and sanded the edges. I made a template
    out of cardboard of the exact size and shape as original, traced that on a piece
    of heavier aluminum and cut that out. I used two small clamps to hold in place
    and drilled 5 3/32 holes and used same size rivets. I put masking tape on the
    side of the rivet heads to keep them from falling out while hammering the other
    ends. These rivets were aluminum and easy to hammer to make a strong and tight
    fit. This stove might not be a collectors delight, but it will sure work as a
    stove. Total price, about $1.25.
  2. Tony Press
    Excellent, straight forward repair! Just what a working stove needs. :thumbup:
  3. shagratork
    A great repair.
    Not only that, but it looks good. :D
  4. presscall
    Stylish job.
    My compliments on using 'proper' and not 'pop' rivets. Nothing wrong with the latter for the right application but it's good to see someone applying the old skills and technology.
  5. roby03
    To all
    I meant to say HEAT SHIELD Repaired. I don't know why I typed windscreen.
  6. hikerduane
    Plumas County, CA
    Real nice job, looks great.
  7. Tony Press
    @roby03
    Maybe a Moderator like @shagratork can change the topic heading to say Optimus 99 Heat Shield Repair...
  8. Afterburner
    ±Finland°
    Would it also protect from the wind that is coming from the tank direction?:doh:If yes, then it's also a windscreen.:lol:
  9. roby03
    To all
    Thanks for all the comments....and nice to see proper title. Here is a flame shot
    of the repaired stove.
  10. roby03
    Thanks Tony, I tried or thought I could change it, but not!
    Roby
