Parts Meva 1 tea test
Discussion in 'Stove Forum' started by hikerduane, May 18, 2026.
  1. hikerduane
    Plumas County, CA
    Picked up this stove recently, thinking the riser would work on an early Optimus 00 Patent. No burner caps or pot supports came with it as usual. No stress cracks. My first attempt at cobbling up some supports. Had burner parts that would work after many times of swapping caps around, even worked sorta with just an outer cap. Working correctly now with a low inner cap and a SH&S outer cap. Switched out the original NRV for a new Swedish one. No matches for the fuel cap gasket, but it holds pressure. Finally delved into making some pot supports, been dragging my feet for over a week to get started, then procrastinated, but was out in the garage late last night and finished the supports. Between figuring out correct measurements, the hardest part was grinding down the ends so they fit into the “D” shaped sockets on the fount.
    IMG_2122.jpeg IMG_2123.jpeg IMG_2127.jpeg IMG_2128.jpeg IMG_2129.jpeg IMG_2130.jpeg
  2. Remus1956
    Los Angeles California
    Looks good man!
  3. hikerduane
    Plumas County, CA
    Thank you, something else to keep dust off the shelves in the garage. Gave me something to do for a few sessions.
    May attempt to make some supports for one of my Solus stoves now.
  4. Remus1956
    i made a jig with bolts in a steel plate to do the bends on mine...getting decent at it
  5. hikerduane
    Plumas County, CA
    I don't have the plate, a hunk of large H beam is too thick that I saved.
